Samsung np550p5c
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    Samsung np550p5c
    Hi
    The problem is broken screen type: ltn156kt06
    I tried this screen: ltn156at19-001
    All I got is a screen with black color then white then green then blue and so on
    I programmed it with the dump of the original screen.... But the same problem
    • 21968
    Re: Samsung np550p5c
    LTN156AT19-001 = 1366x768 LTN156KT06 = 1600x900
    Flashing the EDID isn`t going to work.That screen is simply not compatible. Samsungs are very picky about screen compatibility
    • Chrissygizmo
      by Chrissygizmo
      02-10-2025, 12:33 AM
    • Chrissygizmo
      samsung galaxy ao2s very temperamental after screen replaced
      by Chrissygizmo
      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
      Ive eventually managed to get it on and working but it's very temperamental...
      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
      05-26-2024, 12:05 AM
    • JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
      by JunkmanJimbo
      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
      Please help. Thanks in advance!
      08-12-2025, 11:45 AM
    • Kiberge
      Samsung LH82QENELGC/EN Help needed - Static line on screen
      by Kiberge
      HI guys!
      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
      04-22-2024, 11:28 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
