I working on a MacBook Air 13 2014 820-3437 with the following error Thunderbolt Proximity, MLB Top Side, Airport Proximity, Memory Proximity and Trackpad Skin. I almost replaced all the sensors already and still have the same results. I attached a Photo here.
MBA 13 820-3437 sensor error
Re: MBA 13 820-3437 sensor error
Check if all the same sensors fail without touchpad plugged in.
If yes, probably an issue on SMC "3" SMBus.
Check resistance across R5390 and R5391.
Check voltage and diode mode to ground on SMBUS_SMC_3_SCL and SMBUS_SMC_3_SDA.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
by groomitHi,
I just replaced the battery on a Google Pixel 5.
After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
The rubber seal is on again (as mentioned in various suggestions in other forums).
This smells like a cold or broken solder joint. So I'd like to reflow... -
by BenassHello,
I have a TestiFire 1000 Device with an IR sensor fault. The problem was that the IR sensor had no power.
Initially, I found that R47 had 5V, but it was OL (open loop). I replaced it with another 100 Ohm resistor, and 5V was restored to the IR sensor.
The second problem I found was that R50 (I think) was 4700, but it was also OL. I replaced it with another 470 Ohm resistor.
Despite these fixes, the device was still giving me an IR sensor error. At this point, I was about to give up, until the owner advised me to attach the CUP to... -
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
The TV does not turn on, the standby indicator is on. All voltages are present.
Emms is dead. Not readable, not detected.
Replaced emmc.
But with another dump there is no launch
Terminal log
UART
AC_ON
RPMB key is not yet programmed
HASH1_VERSION=0x00000000 64bit
E-B
FDE enabled
layout pattern onebin by SAR7,0... -
one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
We replaced the SCR with new device,, but the device is not power on as expected.
Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....09-26-2025, 09:00 AM -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM - Loading...
