Lenovo G510 LA-9641P I7
  • Prosatanosz
    • Nov 2015
    • 108
    • Hungary
    Hi!
    After plug in charger 3/5V goes on for 3 seconds. Then off, and died. Need unplug charger a while, and the same symptome. Any idea?
    Thx
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Lenovo G510 LA-9641P I7
    First, visually inspect all the components , than measre the Impedance on all coils/jumpers to see if there is short.
    • Prosatanosz
      • Nov 2015
      • 108
      • Hungary
      Ok. There is no short, or damage. Bios rewritten, cpu changed, cmos battery removed. The first thing was a shorted yellow cap on the 19v rail. I was so happy to find it........
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        still the same symptoms?
        • Prosatanosz
          • Nov 2015
          • 108
          • Hungary
          Yes
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            do u have 3V and 5v reg voltage on 3/5V chip ?
            do u have 19V after 5secons?
            • Prosatanosz
              • Nov 2015
              • 108
              • Hungary
              3V/5V ok for 3 seconds, 19V allways ok.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                and reg voltages?
                • bob42
                  • Sep 2020
                  • 7
                  • Украина
                  Check + 3VLP on pu401 5pin
                  • Prosatanosz
                    • Nov 2015
                    • 108
                    • Hungary
                    Sorry, i give up.
                    • Mazorca
                      • Jan 2017
                      • 463
                      Check power button board if it has one, I just had a toshiba c55-B that displayed same simptoms, on for 2-3 seconds, screen lit up, and then turned off. Possible liquid damage on board.
                      • motormayhem
                        Lenovo T460 Only Charges on One Charger
                        by motormayhem
                        Laptop Question
                        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                        05-12-2023, 01:46 PM
                      • coasterghost
                        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                        by coasterghost
                        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                        System Hardware:
                        Processor: AMD Ryzen 7 PRO 5850U
                        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                        09-08-2025, 10:46 PM
                      • Mita99
                        Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                        by Mita99
                        Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                        Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                        Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                        04-27-2025, 07:20 PM
                      • totto210
                        lenovo legion 5 15-lmh05 nm-c911 charger problems
                        by totto210
                        Hi guys, well the summary is this:
                        the equipment arrived because it did not turn on (it had been the original 230w source the problem) then I feed with my regulated source and without wanting to invert the poles. the equipment turned on and turned off.
                        This damaged the charger and its mosfets both high and low switching.
                        It also damaged the input mosfet (pq102).
                        by chance i had another lenovo legion just like this one and i removed the components and tried to turn it on and it turned on but ....... it burned again the high and low mosfets and switch (pq104, pq105, pq103)....
                        05-23-2024, 10:03 AM
                        Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                        This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                        09-06-2024, 06:40 AM
