Dell xps 9560 la-e331p dead
  • barakuda123
    • Aug 2017
    • 16
    Dell xps 9560
    La-e331p (schematics only available for dell xps 9550 la-361p)
    Similar but vram different
    hi laptop not working
    When motherboard powered on it takes 0.25 amp for about 3 sec then goes back to 0.001
    When at 0.25 amp
    3.3v ok
    5v ok
    1.2v ram ok
    1.0v pch ok
    0.9v cpu vccio ok
    1.0v cpu sa ok
    1.3v gpu ddr ok
    No voltage on pl 1200,pl 1201.1202(cpu vcc core)
    No short detected anywhere
    Problem appears to be in isl95829a
    No pwm vcore1a,1b,1c
    And fccm core only 2v (think should be 5?)
    Isl95829a got
    Vin 13.5v
    5vs
    3vs
    +vccst
    Vr enable
    Vr ready
    Sda,sclk, #alert sygnals communications with cpu ok all 1v
    Replaced isl95829a but still same
    Pu1200,pu1201,pu1202
    Cpu vcore drmos
    1pwm core 0v
    2fccm core 2v
    3 boot 4.5v
    6 vin 13.6v
    14 5vs-5v
    Stuck here bios flashed any help?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Dell xps 9560 la-e331p dead
    Find out DRAMRST or PWRGOOD Ok or not
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      if u have PJP701 or PJP702 try remove the solder and see if pc power on ok.
      • barakuda123
        • Aug 2017
        • 16
        Where i can Measure these signals?
        • barakuda123
          • Aug 2017
          • 16
          if i remove jumper pjp701 and pjp 702 same reaction but takes less amp 0.15 due to this line off but board behave the same
          • barakuda123
            • Aug 2017
            • 16
            I have replaced isl95829a once again and fb_a signal is missing from cpu .....resistance in this line ok
            No communication with cpu?? Dead cpu??
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Check pin 108 DDR3 Slot voltage ? If now supply find out RD35 voltage in out & input side ?
              ALL_GPWRGD ?
              • barakuda123
                • Aug 2017
                • 16
                ALL_GPWRGD ?
                Hi aftet more measurements
                PCH_PLTRST#_EC missing this is probably last signal before vcc_core
                On Uh7
                I've got
                Pin 1 PCH_PLTRST# -0v
                Pin 2 PCH_PLTRST#-3.3v
                Pin 4 PCH_PLTRST#ec -0v
                Im little confused why pin 1 and 2 got same name but are not connected (diode mode)
                Can i connect pin 1 and pin 2 and try to power up the board???
                • barakuda123
                  • Aug 2017
                  • 16
                  [QUOTE=barakuda123;988851]Hi aftet more measurements
                  On Uh7
                  I've got
                  Pin 2 PCH_PLTRST#-0v
                  This signal comes directly from pch ....can I inject 3.3v from other source on pin 1,2 UH7 and power on board??? Will this be safe?
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    [QUOTE=barakuda123;988884]
                    On Uh7
                    I've got
                    uplode the Schematic that you have the my one is different
                    • barakuda123
                      • Aug 2017
                      • 16
                      [QUOTE=techtiger;988930]
                      There's no schematics for 9560 only for 9550 and 9570 There's a boardview for 9560 tho
                      I'm just combining all 3
                      Power sequence os from 9570 tho most if not all start up signals are the same
                      • Weelcup
                        TopTech
                        • Oct 2017
                        • 307
                        [QUOTE=barakuda123;988949]
                        This is the 9560 schematics buddy.
                        • barakuda123
                          • Aug 2017
                          • 16
                          [QUOTE=Weelcup;988959]
                          This is schematics for dell xps 9550.....very similar to dell 9560 but that's no power up sequence thats why I'm using power sequence from 9570
                          Dell 9550 =la-c361p
                          Dell 9560 =la-e331p
                          Dell 9579 =la-g341p
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            First remove UH7 & see if the voltage is back pin 5/ 1/ 2 , Check pin 108 DDR3 Slot voltage ? If now supply find out RD35 voltage in out & input side ?
                              • 21999
                              The la-e331p schematic is available on a few paid sites,it hasn`t leaked onto any free sites yet.
                              • barakuda123
                                • Aug 2017
                                • 16
                                Can you please share where? Already paid few times for 9569 schematics and it always turned out to be 9550 (vinafix)...i will be happy to pay for 9560 la-e331p schematic
                                • barakuda123
                                  • Aug 2017
                                  • 16
                                  Hi after removing uh7 still no voltage on pin 1 or pin 2(pch_pltrst#) on this board its rd31 i believe you asking for ddr4_dramrst# and h_dramrst# when i power up the board voltage jums for 0.5 sec to 50mili volts than down to zero
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    pin 5 UH7 do you get 3V ? if you have a hot air gun heat the PCH and see as for the Schematic RD31@ no stuff find out RD35 or put a jumper 1.2V & see what is the resistance to GND on RD31
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      Can you annotate the pins of UH7 on the picture of the board with your voltage measurements?
                                      • Weelcup
                                        TopTech
                                        • Oct 2017
                                        • 307
                                        [QUOTE=barakuda123;989017]
                                        Dell 9550 =la-c361p
                                        Dell 9560 =la-e331p
                                        Dell 9579 =la-g341p
                                        I see. I agree the power should be close to the one with 9570 or 9550..
                                          DELL XPS 9560 Notebook 15 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9560 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9560 boardview and 9560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9560 Notebook...
                                          09-06-2024, 07:11 AM
