Equivalent for ISL88550AIRZ on JBL00 LA-3801P Rev 2.0 (A01)
  • vettouch
    • Sep 2020
    • 68
    • Nigeria
    Hi members, I have DELL_E6400 with display fault, I presumed after test with DMM. No voltage on RAM section. RAM IC has voltage, but no output voltage.
    Which other IC can be used for replacing ISL88550AIRZ? Thanks for your anticipated assistance. Vettouch
  • stingerchamp
    Ddr3/ddr4 ram section voltage requirements(working)
    by stingerchamp
    Follow this guide to verify voltage at RAM SECTION
    DDR 3 ram section voltage check list at ram slot
    DDR3 operating voltage VDD (at coil )= 1.5V PINs 75,76 ram slot
    VRef_DQ = 0.75 V at PIN 1
    VTT/Termination voltage= 0.75V PINs 203,204
    VRef_CA. = 0.75V PIN 126
    VDD SPD = 3.3V PIN 199
    SDA data = 3.3V PIN 200
    SCL clock = 3.3V PIN 202
    DRAM_RST# = 1.5V PIN 30
    DDR 3L ram section voltage check list at ram slot
    DDR3L...
    12-12-2020, 02:07 AM
  • Instafixx
    Macbook A2179 820-01958
    by Instafixx
    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
    I checked the Power Sequences below and found this -
    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
    05-20-2023, 05:19 AM
  • Fernon@Repair
    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
    by Fernon@Repair
    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
    VCCIO voltage ok
    VCCSA Voltage OK
    VCCPLL Voltage OK
    Ram Voltage ok
    RamVTT OK
    VPP 2.5 OK
    But No Core Voltage
    and i want to this vrm ic datasheet or pinout (ISL69269)
    anyone have this ic pinout voltages?...
    06-25-2025, 07:19 AM
  • electron_jj
    Panasonic TH-L42D25A checking the PSU output voltage
    by electron_jj
    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
    08-29-2021, 08:13 AM
    Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
    by sam_sam_sam
    I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
    The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
    Now...
    06-09-2024, 10:57 AM
