Hp bdl50 la-d703p
  • favas
    • Feb 2017
    • 5
    • india
    Hp bdl50 la-d703p
    No display on off after 5 second
    5v 3.3v ok
    ram voltage missing.ram ic changed but no voltage getting
    please help me
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hp bdl50 la-d703p
    Without ram, board remains on??
    • Ferimonka
      Dell Latitude 7420, 7320 voltage changed
      by Ferimonka
      Hi there,
      I got 2 Dell laptops with a locked bios (dell management protection).
      When I sent the dumps to this forum I got unlocked .bin files.
      The issue I am getting the voltage on the bios chip pins has changed once I soldered the chip back (with the unlocked even original bios file) and doesn't turn on anymore.
      Before I started to re-program the chip the voltage on the pins were 3.3V almost on each pin. Once I soldered the chip, voltage changed to 1.9V or 1.3V on few pins. No 3.3V anymore.
      I appreciate any help to get me this...
      07-18-2022, 02:11 AM
    • Fernon@Repair
      Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
      by Fernon@Repair
      i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
      VCCIO voltage ok
      VCCSA Voltage OK
      VCCPLL Voltage OK
      Ram Voltage ok
      RamVTT OK
      VPP 2.5 OK
      But No Core Voltage
      and i want to this vrm ic datasheet or pinout (ISL69269)
      anyone have this ic pinout voltages?...
      06-25-2025, 07:19 AM
    • electron_jj
      Panasonic TH-L42D25A checking the PSU output voltage
      by electron_jj
      Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
      I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
      08-29-2021, 08:13 AM
      Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
      by sam_sam_sam
      I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
      The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
      Now...
      06-09-2024, 10:57 AM
      ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
      3+1 Voltage Regulator for IMVP-7/VR12 CPUs
      Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
      core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
      configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
      serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
      Based on Intersil's Robust Ripple Regulator...
      11-05-2024, 03:24 PM
