820-3435 water damaged
  • hosoi
    • Jul 2020
    • 30
    Hello, I got this water damaged macbook air which my main question is about Q7630 which is blown and because of the way it was, I'm wondering if worth it to troubleshoot this MB, if you pay attention to the picture you will see that there might be some damaged layer below, actually if I connect the charger orange light comes on but it doesn't charge. please see pic.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-3435 water damaged
    Well remove it and see how bad it is. There is a chance that it damaged the PCH though.
    • hosoi
      • Jul 2020
      • 30
      it looks very bad. what do you think
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        clean with isopropil alchool 99.9% and make picture again. check if some pinpoint is shorted. if not it can be repaired.
        • RetroComputingGrotto
          Water Damaged Toshiba 48L1435DB
          by RetroComputingGrotto
          I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
          The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
          10-07-2024, 08:23 AM
        • rzsn
          water damaged G513I
          by rzsn
          Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
          Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
          12-22-2024, 09:02 PM
        • phantomEVO
          [help]820-01521 WATER DAMAGED
          by phantomEVO
          HELP! audio board+its flex+powerbtn flex water damaged (an hole on audio board)!!! chnged both, but i have 5v on both ports:
          https://files.fm/f/6gjpqyjw3q
          here some measurements
          ppbus_g3h 12,29v
          PP3V3_G3H 3,29v
          pp3v3_upc_xa_ldo pp3v3_upc_xb_ldo 3,27v
          PP1v8_UPC_XB_LDOD PP1v8_UPC_XA_LDOA 1,8v
          PP1v8_UPC_XA_LDOD PP1v8_UPC_XA_LDOa 1,8v
          PP1V1_UPC_XA_LDO PP1V1_UPC_Xb_LDO 1,1v
          with battery connected, as soon as i connect the cable, i see direclty 20v, but stuck at 0,0250
          10-24-2025, 04:23 AM
        • estabilito
          Dell Latitude E5590(La-f411p) water damaged
          by estabilito
          I have water damaged Dell Latitude E5590 around charging ic.
          Laptop was dead but i replaced some components like capacitors, resistors, resoldered charger(intersil 9538h) but traces under PQ904 dual mosfet(AOE6936) was burnt.
          I rebuilt traces and both mosfets(PQ904 and PQ905) and after all this work laptop started turning on.
          I dont have battery so i want to be sure if laptop behaviour is normal before buying.
          On PL902 i have weird voltage around 5Volts, on battery socket voltage looks normal - 13.5v.
          Is this voltage on pl902 normal?...
          03-08-2025, 06:22 PM
        • martyjelen
          Lenovo ideapad D330-10IGM can't power on (water damaged)
          by martyjelen
          Hello, I have laptop Lenovo ideapad D330-10IGM which won't turn on. It was water damaged, but as I know it was clear water. I cleaned the board already.
          Now, I noticed, that some component is heating up (see picture) there is a code GAASKJ on it. I don't really know what component is this and what is it's function.
          It seems that charging works normally because current draw is about 1A and voltage is 19V.
          Could you help me with it?
          Thank you
          BTW there is a flux on component. No damage.
          Martin...
          10-04-2023, 04:03 AM
