HP Pavillon G- Fan error (90B)
  • senakahks
    • May 2020
    • 39
    • New Zealand
    I trying to fix a l HP Pavillon G which gives the error message 90B fan error.
    Fan is slowly running for about 2 seconds and stop about 2 seconds. that runs as a cycle. What could be the problem.
    No much dust and connector has no problem.
  • peste
    • Dec 2016
    • 13661
    • ROMANIA
    Re: HP Pavillon G- Fan error (90B)
    maybe the fan is blocked..take it out, check it, grease it if possible..if you can't test the laptop with another fan ..
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3628
      • slovakia
      if fan is spinning and ges in cycle mostly conroller circuit is ok. maybe bad fan tacho.
      u have 3 or 4 wires fan?
      • senakahks
        • May 2020
        • 39
        • New Zealand
        3 wire fan
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
        • sushilachuthan
          APC UPS error P13
          by sushilachuthan
          one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
          the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
          The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
          We replaced the SCR with new device,, but the device is not power on as expected.
          Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
          09-26-2025, 09:00 AM
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
