820-2533 Macbook Pro - SYS_ONEWIRE: 0
  • senakahks
    • May 2020
    • 39
    • New Zealand
    15 inch macbook pro charger bulb doesn't come on. Seems there is a problem with SMC. The measured voltages given below. What could be the issue and and how can I go ahead?
    PPBUS_G3H: 12.6
    PP3V42_G3H: 3.4
    SMC_BC_ACOK: 3.2
    PP1V2_S5_SMC_VDD
    SMC_RESERT_L: 3.3
    SYS_ONEWIRE: 0
    SMC_PM_G2_EN: 3.4
    PP5V_S3:0
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-2533 Macbook Pro - SYS_ONEWIRE: 0
    SMC should be ok.
    Try another Magsafe and DC-in board.
    Check voltages on U6900 and U6901.
    • senakahks
      • May 2020
      • 39
      • New Zealand
      SMC_BC_ACOK_VCC is 3.3V
      So U6901 is giving the proper output.
      U6900 getting the 3.3V to VCC pin. R6929 is not open.
      Magsafe is woking fine with another computer
      • piernov
        • Jan 2016
        • 4439
        • France
        What about voltage on pins 4 and 5 of U6900?
        And resistance to ground on pin 4 and 5?
        • senakahks
          • May 2020
          • 39
          • New Zealand
          U6900
          Pin4 = 0V
          pin5 = 0V
          Resistance to ground
          Pin4 = 123 Ohms
          Pin5 = 1.7 M Ohms
          • piernov
            • Jan 2016
            • 4439
            • France
            Remove U6900 and check voltage and resistance to ground on pin 4 again.
            • senakahks
              • May 2020
              • 39
              • New Zealand
              Pin 4 pad
              Voltage 3.4V
              resistance to ground 5.4 M Ohms
              • piernov
                • Jan 2016
                • 4439
                • France
                Seems like U6900 was bad, replace with a new one (or from donor board).
                • senakahks
                  • May 2020
                  • 39
                  • New Zealand
                  Great support. Thank you!
                  So, even multimeter is not beeping, a resistance ~ 100 ohms via a chip to ground can be considered as a short to ground. Isn't it?
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    Yes, in fact continuity mode with beep will often be misleading. It really depends on the line you are measuring. On CPU VCore power rail you'd have like 6 ohms and it'd beep but that's normal. On a data line you often expect at least a kiloohm.
                    • senakahks
                      • May 2020
                      • 39
                      • New Zealand
                      Valuable information. After replacing U6900, now green bulb works on charger. Fan is not working yet. Have to check now.
                      • senakahks
                        • May 2020
                        • 39
                        • New Zealand
                        Now SYS_ONEWIRE: 2.8V
                        Green Light is ON
                        S3 rails are not active yet.
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          You have to trigger power button for this machine to turn on.
                          • senakahks
                            • May 2020
                            • 39
                            • New Zealand
                            Tried to trigger by touching the ground to SMC_ONOFF_L. Fan doesn't move at all.
                            • senakahks
                              • May 2020
                              • 39
                              • New Zealand
                              Some voltages may be useful:
                              PM_PWRBTN_L: 3.4V
                              SMC_ONOFF_L: 3.4V
                              PM_SLP_S4_L: 0V
                              When trigger SMC_ONOFF_L, PM_PWRBTN_L goes down and come up.
                              • senakahks
                                • May 2020
                                • 39
                                • New Zealand
                                The charger I have used is a 15V one. So, once charger is changed, SYS_ONEWIRE gives 3.3V
                                Still no luck with FAN
                                • piernov
                                  • Jan 2016
                                  • 4439
                                  • France
                                  You must use a good 85W Magsafe.
                                  • senakahks
                                    • May 2020
                                    • 39
                                    • New Zealand
                                    Yes. That is what I am using now.
                                    What can I check for missing PM_SLP_S4_L?
                                    • envym
                                      by envym
                                      Hi everyone!
                                      06-27-2025, 08:54 AM
                                    • Flasman90
                                      Macbook Pro DFU Restore Issues
                                      by Flasman90
                                      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                      08-30-2025, 10:27 AM
                                    • tobeend
                                      Bypass mdm macbook m2 ventura
                                      by tobeend
                                      1. RESET MACOS WITH IPSW
                                      a. Power off MacBook, press and hold the power button to enter Recovery
                                      b. Open Disk Utility, remove Macintosh HD
                                      c. Reboot, connect to the network to Activate Mac.
                                      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                      e. Release the other keys, but keep holding the Power key for another 10 seconds
                                      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                      05-26-2023, 07:18 AM
                                    • SarcasticOP
                                      General question about MacBook power rails for repair.
                                      by SarcasticOP
                                      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                      • PPBUS_G3H (12.6V-12.8V)
                                        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                      • PP3V42_G3H (3.42V)
                                        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                      • PPVRTC_G3H (3.3V)
                                        • This
                                      12-12-2024, 05:50 PM
                                    • obelix24
                                      A2941 Macbook air 15” - 5V 0a
                                      by obelix24
                                      I’m working on one macbook air 15” m2 that was water damaged.
                                      keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                                      i’ve put macbook in shelf and order new screen so i can fully repair it.
                                      Now i got the screen and macbook stays at 5v 0a.
                                      i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                                      i don’t have schematics so i don’t know where to start can someone help me?...
                                      03-27-2025, 01:19 PM
