HP 15-ac105nj have a short on ROM (bin4+8)
  • eng.jaudat
    • Aug 2016
    • 63
    • Palestine
    Hello my friends,
    i know that bin 4 on ROM chip is ground
    and bin 8 is for VCC
    i have a short between ground and both of bin 4 and bin 8 on the ROM Chip
    how i can troubleshoot that problem?
    is that a processor fault?
    can i inject bin 8 with 3.3V using the power supply?
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: HP 15-ac105nj have a short on ROM (bin4+8)
    what is your Bord ID don't' inject 3.3V only 1-1.5V you can increasing amps , check the resistance to GND on pin 8 BIOS chip does the MB have 2 Bios chips ?
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Originally posted by eng.jaudat
      Hello my friends,
      first is try to take off the bios chip from the mobo then test the ic pin look for short.. then try to check the board and check it for short, what is the part number of you eeprom ic. get the datasheet then compare the pinouts. try to buy the same eeprom if defective .post here what you discover.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Pin8 of main bios shorted to gnd indicates a short on PCH-The pch itself may be shorted or some component on 3V rail may pull that rail to ground. Remove the bios chip from mb and check pin8 resistance again. Your 3v coil is very likely shorted-so remove 3v coil and check which side is shorted. Inject 1V on that rail and gradually increse amps to see if there is any warm component. Good luck.
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • fab13
          Nintendo Switch lite charging chip heats up and does not short circuit
          by fab13
          Hello everyone
          Small technical problem on a Nintendo Switch lite
          Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
          After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
          When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
          Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
          09-16-2023, 04:59 AM
        • playit
          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
          by playit
          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
          09-02-2023, 02:43 AM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • MisterAIL
          820-00840 / No boot / PP3V3_G3H Short to ground
          by MisterAIL
          Firstly sorry for my english, french guy inside.
          I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
          History is a day, nothing happened when opening the laptop.
          Nothing special inside, no corrosion, no liquid damage, never opened.
          First, with the logicboard alone on the desk, mesures are :
          5v017 and 0.000 amp. nothing else.
          Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
          10-13-2021, 11:42 AM
