hi everyone i have dell inspiron N5110 no display
  • arber1232
    • Dec 2019
    • 370
    • Albania
    hi , my laptop dell inspiron N5110 not display . i have brights but not have figure . Can you any idea for this problem .
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hi everyone i have dell inspiron N5110 no display
    Check Hall1 connector on the mb.What is the voltage on PIN2 and 4?? If pin2 has no voltage, then jumper a wire between pin2 and pin4 and you will get display for sure.
    • arber1232
      • Dec 2019
      • 370
      • Albania
      pin 2 i have 19 v .
      • arber1232
        • Dec 2019
        • 370
        • Albania
        pin 4 i have 3.3v
        • arber1232
          • Dec 2019
          • 370
          • Albania
          this is shcematic
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Originally posted by arber1232
            pin 2 i have 19 v .
            It's impossible to have 19V on pin2. Check your measurement again. Dont jumper if you really have 19V on pin2 but i think its very very unlikely.
            • arber1232
              • Dec 2019
              • 370
              • Albania
              see this shcematic i have 1.2.3 pin i have 19 v and 4 pin i have 3,3 v
              • piernov
                • Jan 2016
                • 4435
                • France
                Baclight but no image? Black screen or white screen?
                Could always be the usual dead GPU on this machine.
                • lapfix
                  • Mar 2020
                  • 2720
                  • my workshop
                  Can you give us the voltage on U4901 !
                  • arber1232
                    • Dec 2019
                    • 370
                    • Albania
                    its black screen. this laptop not have gpu . i change procesor but its same problem , in u4901. i have 3.3v its ok .. i think problem is in pin4 Nc i not have voltage , in same board is 1,2 v in pin 4
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Hall sensor is there on Pg70 and pin1 and3 are non connected. How you have 19V there. The hall sensor is located at the extreme right hand lower side near 3/5v regulator IC. I still feel you are measuring at some other location or your measurements are wrong.
                      • arber1232
                        • Dec 2019
                        • 370
                        • Albania
                        see in schematic bro is 19v for light lcd pin 1,2,3 . pin 4 is NC and i not have voltage
                        • arber1232
                          • Dec 2019
                          • 370
                          • Albania
                          see is pin 1.2.3.4.5
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            You've proved i was right in assuming that you are measuring at wrong location. You are measuring at LVDS ConnectorLCD1. I asked you to measue HALL1 connector for which i've given you even an idea about its location.
                            Now locate it correctly and measure pin2 and 4.
                            • lapfix
                              • Mar 2020
                              • 2720
                              • my workshop
                              What's the voltage on LVDS connector pin : 1/5/15/26/30
                              • arber1232
                                • Dec 2019
                                • 370
                                • Albania
                                pin 2 i have 1,3v and pin 4 i have 3,3 v
                                  • 20898
                                  if further proof is needed..
                                  https://www.ebay.co.uk/itm/H7PRC-BRA...-/153139332342
                                  • arber1232
                                    • Dec 2019
                                    • 370
                                    • Albania
                                    a have 19v.1,7v,3,3v. 0v and pin 30 i have 3,3 v
                                    • arber1232
                                      • Dec 2019
                                      • 370
                                      • Albania
                                      Originally posted by SMDFlea
                                      yes understand jump pin 2 and 4 now i have more brights but not figure
                                      • arber1232
                                        • Dec 2019
                                        • 370
                                        • Albania
                                        when I try it with a 14 inch screen the laptop gives me pictures but gives it distorted
