x550vx fan not working
  • trmrtts
    • Jan 2014
    • 38
    • turkey
    hi everybody
    i have x550vx main board.this board working ,have image but fan not working
    i tried this
    bios update
    changed ec
    and havent fan0_pwm voltage
    fan socket voltage
    fan0_pwm=0v
    fan0_tach=3v
    5vs_fan=5v
    I/O voltage
    31pin fan0_pwm=0 volt
    47 pin fan0_tach=3 volt
    and u5003 voltage
    cpu term u5003
    5pin=3.3v
    3pin cpu_therm=3.3v
    4 pin +3vs=3.3v
    1 pin=3.3v
    whats wrong
  • Duranitron
    • Jul 2014
    • 543
    • Philippines
    Re: x550vx fan not working
    is the laptop working fine? make sure to test the pin without the cpu fan..test the fan outside to confirm its working.. and make sure the cpu fan is not the one shorting the fan0_pwm to ground.. if not.. try back tracing.. the pwm signal is produced by the fan controller ic.. try to check that...
    • trmrtts
      • Jan 2014
      • 38
      • turkey
      laptop working,fan working outside with power supply
      • Duranitron
        • Jul 2014
        • 543
        • Philippines
        try to hot wire it to keep the fan working unless you have a lot of time to trace it back why its not working,, follow the schematics... https://www.badcaps.net/forum/attach...3&d=1435773716
        • MMH3
          Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
          by MMH3
          i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
          Never ever i experienced problems with that.
          Now i have one 5050sff machine, where this jumper isnt working at all.
          I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
          The history of the machine is that i used it in my office...
          03-23-2025, 09:28 PM
        • DynaxSC
          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
          by DynaxSC
          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
          The board is generally working now, all PCIe ports are working, Windows installs normally.
          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
          03-10-2025, 12:27 PM
        • obelix24
          Macbook Air 2020 (a2179) - touch id not working
          by obelix24
          Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
          I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
          02-09-2025, 12:57 PM
        • hopkok
          Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
          by hopkok
          Hi masters, I need your help.
          I am working on Lenovo Legion 16ITHg6
          Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
          INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
          My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
          AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
          Power LED is not working as well, power button working well.
          UI26 ??? is there any firmware too? Powered by +3VALW_AG.
          Motherboard...
          05-04-2025, 09:35 AM
        • bociub
          laptop freezes, usb 2.0 not working, usb 3.0 working
          by bociub
          Hi there,
          It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
          Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
          08-25-2024, 03:44 PM
