Ailenware 17 R4
  • davem12
    • May 2019
    • 11
    Ailenware 17 R4
    I am working on an Ailenware 17 R4 M/B BAP10 LA-D751P Rev 1.0
    I am getting a two red and one blue code on the power button which said CPU fail. I tried removing the battery connector and the bios batter reset, no help. I also re-flowed the CPU and I still have the same error. I believe that the CPU overheated and failed, is there anything else I can try?
    Thank You
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: Ailenware 17 R4
    try to check all the voltage rail.. specially the voltage for the processor..1.2 or 1v is good.. but try to see if it overheats.is the processor fan spinning? did you check the fan? reflowing the processor without the proper tool can kill it.. if there is no processor voltage.. try to look for short circuit in the processor side.. short circuit meaning 0 ohm. it is not common to have a defective processor because it has a built in protection for over heating and over voltage..but of course it has always an exception. my opinion.. its likely to have a failed chip if the processor have a built in gpu..
    Never stop LEARNING because life never stops TEACHING!
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Re: Ailenware 17 R4
      May be bad SMD CPU caps.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • davem12
        • May 2019
        • 11
        Re: Ailenware 17 R4
        Thank You for your feedback and troubleshooting tips, I will look into this.
        I need to figure out where is the voltage rail at.
        What happened was the owner never cleaned the cooling fans and they were full of dust and hair until she got a CPU overheat code. When it is powered on now, the cooling fans come on for 7 seconds and goes out for 3 seconds. It does this several times until the power led flashes 2 red and 1 blue code, then the cooling fans go to full speed.
        When researching the CPU failure, this has been a common occurrence with this laptop and some were within a year old.
        Thank you
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Re: Ailenware 17 R4
          You need to check voltage on all big grey coils.
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            Re: Ailenware 17 R4
            experienced that symptoms in Lenovo laptop the fan is gummed up, laptop always power off for 10 minutes but the costumer keep on using it for almost a year. see how reliable intel processors are then this symptom came.. no display the fan spins at full speed. all voltage rail are at the correct values.. what i did is clean the processor fan put some fresh thermal paste and i reflash the bios.. that solves it.. maybe try to reflash the bios.. the frequent on and off state of the unit must corrupted the bios..
            • davem12
              • May 2019
              • 11
              Re: Ailenware 17 R4
              Thanks for all the info,
              I tried using the SOIC clip and got errors. I will de-solder the chip and read it and save original Bios. Is there any specific Bios that worked well for this board. It is a Winbond 25Q80DVS1G chip.
              Thank You
              David
                • 21960
                Re: Ailenware 17 R4
                Thank You
                David
                The bios you want is marked 25Q128 . https://www.badcaps.net/forum/showthread.php?t=85876 .You can try the bios from post #12 ,if you want your own service tag adding you should post your own bios backup in that thread.
                • davem12
                  • May 2019
                  • 11
                  Re: Ailenware 17 R4
                  Wow,
                  That was a really quick response. Went to take it apart and just found the 25Q128 labeled UH4 and was going to update my findings and you beat me too it. Thanks for the information and the link
                  Dave
                  • davem12
                    • May 2019
                    • 11
                    Re: Ailenware 17 R4
                    I flashed the firmware, no help. I found a leaking inductor at the CPU. The inductor measures 4.18mm LxW 1.83mm H. I believe that it is a series 4020 chip. The part I found is SRP4020TA-1R0M, would this be the correct one and will this cause the CPU overheat fault code?
                    Sorry for the noob questions. I'm new at this.
                    Thank You very much for your help
                    Dave
                    • Duranitron
                      • Jul 2014
                      • 544
                      • Philippines
                      Re: Ailenware 17 R4
                      1uH inductor coil try to clean the board and put new 1R0 coil try also remove the mosfet connected to this coil and replace it.. and see how it goes... please post progress
                      • ahmedtou
                        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                        by ahmedtou
                        help me please
                        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                        I will share all the details with you, including the disc information.
                        Code:
                        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                        Current Profile: BD-R
                        Disc Information:
                        Status: Empty
                        State of Last Session: Empty
                        Erasable: No
                        Free Sectors: 12,219,392
                        Free Space: 25,025,314,816 bytes
                        Free Time: 2715:27:17 (MM:SS:FF)
                        Next
                        08-27-2025, 08:49 AM
                      • Zarithya
                        Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
                        by Zarithya
                        I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
                        11-02-2025, 06:26 AM
                      • paparazzo79
                        HDD in external enclosure failed, may I use external enclosure with other HDD?
                        by paparazzo79
                        Hello.
                        I own Seagate Expansion drive which for me unknown reason has failed yesterday.When connecting to PC I am getting access denied message and whole partition in Disk Managment is in RAW format.
                        So I dismantled the case thinking I may use the inside HDD as internal sata device in a computer but even like that I am getting access denied message.
                        The drive is Sagate Exos.
                        My question is may I use the enclosure with other internal drives (I own 3 internal 3.5 inch WD drives with 13TB capacity)?
                        I mean maybe that is even not advisable since electronic card (from pic...
                        10-28-2025, 01:01 PM
                      • Lostdotfish
                        KZG caps failed on a NOS motherboard - never been used...
                        by Lostdotfish
                        This is a new one on me. I picked up a new old stock DFI 865PE Infinity board recently. It's completely new, never used. While inspecting it I noticed some unexpected bulging caps...
                        All of the 6.3v 1500uf caps had failed in place, despite the board never seeing use and being stored sensibly. I pulled the 16v caps that are the same series as a precaution and will replace them all.
                        10-15-2025, 04:29 AM
                      • modtool
                        Lenovo Legion 5 15ARH05H, NM-D281 Rev 1.0, "BIInitializeLibrary failed 0xc0000185" and bios freezing
                        by modtool
                        Dear members,
                        I have a problem with this machine that still I can't solve, I hope some of you can suggest me something.
                        I was the first one to open the machine and touch the mainboard, in fact the Lenovo seal was intact the first time that I unscrewed all the internal screws.
                        The ower told me that it was working very good until Windows kicked "something like a firmware update" (owner's words) then the system started acting weird.
                        When you try to start it, some seconds after having pressed the power button, Lenovo splashscreen appears, then after 1 second, in the...
                        01-15-2024, 08:56 PM
