pls help HP 250 G4 NO POWER .
  • mo000
    • Nov 2017
    • 284
    • algeria
    Hi everyone
    hp 250 g4 LA-C701P is dead
    when i plug in the charger the power led is on but when i press the power button nothing happen
    when i press the power button the ic PU2 (RT8243AZQW 3/5V) becomes hot ; i change it with new one but same problem
    EC_ON , MAINPWON signal are exist and LDO3 AND LDO5 Exist too
    VIN voltage exist
    everything is ok and no short on output pins
    but i don't know why the ic becomes hot .
  • mo000
    • Nov 2017
    • 284
    • algeria
    Re: pls help HP 250 G4 NO POWER .
    any ideas .
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      Check boost capacitor and feedback rasistor
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        What is the voltage on pin 13 of PU2 when you turn it on?? Impedance on coil PL8/PL9 in diode mode?? Resistance in Ohms mode??
        • mo000
          • Nov 2017
          • 284
          • algeria
          pin13=3.3
          PL9 1014ohms
          but pl8 360ohms sometimes becomes 30ohms .
          • mo000
            • Nov 2017
            • 284
            • algeria
            can you specific pls .
            • mo000
              • Nov 2017
              • 284
              • algeria
              someone help pls .
              • mo000
                • Nov 2017
                • 284
                • algeria
                i desolder the jumber PJP3 but same problem i think the whole problem in 5VALW side .
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Remove jumper PJP2 also and check again whether PU2 is still getting hot. may be bad KBC.
                  • mo000
                    • Nov 2017
                    • 284
                    • algeria
                    I do but PU2 still getting hot .
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Measure resistance on all pins of PU2 and voltage on each pin. Are you sure you soldered a new PU2 or pulled from scrap mb??
                      • Duranitron
                        • Jul 2014
                        • 544
                        • Philippines
                        op said i change it with new one but same problem.
                        something is shorting pu2.. if you done desoldering the jpj2 jpj3. and still the ic overheat.. maybe its a bad ic batch... can you picture the pu2 for us.. tnx..
                        Never stop LEARNING because life never stops TEACHING!
                        • mo000
                          • Nov 2017
                          • 284
                          • algeria
                          i pulled from working motherboard , i'm sure .
                          • mo000
                            • Nov 2017
                            • 284
                            • algeria
                            yes i desolder jpj2 and jpj3 and i also desolder pl8 but pu2 still overheating without output .
                            • mo000
                              • Nov 2017
                              • 284
                              • algeria
                              unfortunately the client take back his laptop , thnx mcplslg123 and duration for help .
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                I'll still bat for this ic being bad or badly soldered. However, its useless now since its no more with you.
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
                                  09-06-2024, 05:59 AM
