820-00138-A Q7706 PPBUS_G3H Short
  • mferna14
    • Jun 2018
    • 1046
    Hi., I am working on a Apple Macbook Pro Retina A1398 15.6" 820-00138-A., Not turning on (Dead). There was liquid spill near U7200 & slight green stuff near the SMC. Replaced the U7200., Now I get the green light, but there is a severe short on PPBUS_G3H, almost 0 ohms. Just to narrow down the trouble shooting & verify where the short was, I removed the 2 fuses F7140 & F7141. After removing the fuse I surely get back PPBUS_G3H 12.8V on L7130, now atleast I know that the short is across the fuse. Has anyone found the short on this logic board after the fuses or can anyone inform me what further components should I check. The boardview which I have is not of the exact match or anyone has a board view for this model. Thanks
  • ibdoctorate
    • Feb 2020
    • 5
    • Nigeria
    Re: 820-00138-A Q7706 PPBUS_G3H Short
    U can search on google for the but doardview with the board number to download boardview
    • mferna14
      • Jun 2018
      • 1046
      Please view the photos, all the mark caps have reading of nearly 0 Ohms across them.. Do you think the CPU is shorting the caps. Any ideas will be appreciated... Thanks
      • piernov
        • Jan 2016
        • 4439
        • France
        What's the exact resistance to ground? ("almost 0 ohms" is not precise enough)
        • mferna14
          • Jun 2018
          • 1046
          Seriously the meter reading across all the caps you see in marked on the photos shows 0 ohms., something is completely short to ground, either its the CPU/GPU or one of the caps, which I am doubtful now since the caps on the CPU SR1ZX too when I take a meter reading it almost 0 ohms. Physically I do not see anything burnt or bursted. Do you think its the CPU/GPU since the tiny caps on it too are show 0 ohms???
          • reformatt
            • Feb 2020
            • 1518
            Just received one of these today with dead short across PPBUS_G3H. No prizes for guessing where the source of that one was.
            U7310 was short, and so was the CPU; confirmed with voltage injection and thermal camera. So whenever I see this, I check the driver and sure enough, there was the smallest amount of liquid damage to the sense pins of U7200. I really hate how these things self destruct with something like this.
            • DynaxSC
              Extreme High Current & Low Voltage Short Killer ??
              by DynaxSC
              Hi Folks
              I'm looking for a extreme high current short killer solution for a reasonable cost.
              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
              After taking off the socket, the shorts dissappear again.
              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
              10-15-2024, 10:13 AM
            • Stephen
              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
              by Stephen
              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
              02-06-2025, 12:03 PM
            • adelfr2009
              HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
              by adelfr2009
              I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
              After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
              09-28-2025, 10:21 PM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • aaronkatrini
              Help me find the short circuit on this WORKING Nvidia GTX1650
              by aaronkatrini
              Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
              Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
              04-18-2024, 03:15 PM
