Embedding Windows OEM key into BIOS
  • KHOR3S
    TZM
    • May 2019
    • 10
    • Croatia
    Hello!
    There was a problem with BIOS on my Dell Latitude E7440. I've made a backup just in case and reflashed both EC and MAIN BIOS. After I had to do update to latest version because the laptop would not turn on. (I've managed to turn it on once in 10-20 tries). Now it works just fine but I lost the embedded OEM key.
    I have the key from original backup and I've tried to use ME Tool to change the key but it does nothing.
    Found the address line where the key is stored but when I write it in new dump also nothing happens.
    Is there any way to embed the key again?
    Thanks!
  • lapfix
    • Mar 2020
    • 2744
    • my workshop
    Re: Embedding Windows OEM key into BIOS
    Post the new dump and the old one
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
      by Vesko356
      08-11-2023, 03:27 AM
    • abel2b
      Hello, Can anybody help with how to recover DMI and Windows Key from HP 14-DQ1004LA Bios
      by abel2b
      Can someone teach me how to edit New *.bin with DMI and Windows Keys from broken bios.
      where should I look (OFFSET) in old dump?
      What must be copied to make new functional bios?
      MY machine is:
      HP 14-DQ1004LA
      S.N: 5CD0080M17
      Background: Tea was spilled on my notebook accidently I imediatly, turned off, unplugged and opened to disconnect battery, I cleaned everything thoroughly, I checked all power supply coils for shorts and all good, except Vcore coil ohms at 0.1 ohms, but I searched around and it seems it is ok. I powered up the board , and all voltages...
      06-30-2025, 09:54 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
