Dell 5537 2 beeps
  • luckydip
    • Aug 2016
    • 159
    • uk
    Dell 5537 2 beeps
    Hi guys
    I need help with a ram issue - power button pressed, fan spins, solid white light at front and 2 beeps. I get 2 beeps with one brand and 4 beeps with another type - so ram is being detected.The two data lines are fine at 3.3v.
    1.35V is missing on PL200 which I assume is the ram supply voltage. SYSON (pin8 PU200) is missing, is this the enable signal? Do I need to check the SIO?
    thanks
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Dell 5537 2 beeps
    SYSON should come up after SLP_S4# from the PCH comes up. Check if SYSON or +1.35V are shorted to ground.
    Make sure you are using DDR3L btw.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • cygron
      Dell Latitude 3440 2 Beeps Problem
      by cygron
      Model: Dell Latitude 3440
      Board id: DL340-HSW MB 13221-1 Rev: A00
      Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
      PL4503 - 3.3V
      PL4101 - 5V
      PL4902 - 1.35V
      PL4801 - 1V
      PL4701 - 1.7V
      PL4401 - 17V
      PL5101 - 0V
      PU5102 pins -
      Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
      Pin 2, 4 - 0V
      Pin 3 - 0.95V
      Pin 5 - 2.87V
      Pin 6 -...
      04-20-2025, 03:46 AM
    • tech_guru
      Dell Inspiron 5558 8 Beeps
      by tech_guru
      Hello.
      If you can help with this one please...The laptop does 8 beeps at boot which as I see is LCD error. The laptop shows image to external monitor normally. New screen flex and screen does not change anything.
      So I took measurements in the LCD socket (LCD1):
      DCBATOUT_LCD 19V
      LCDVDD_LCD 3.3V
      DBC_EN_R 0V
      EDP_HPD_CONN 3.2V
      LCD_TST_C 0V
      EDP_AUX 3V
      EDP_AUX# 0V
      EDP_TX0# 0V
      EDP_TX0 0V
      EDP_TX1# 0V
      EDP_TX1 0V
      LCD_BRIGHTNESS 0V
      BLON_OUT_C 0V
      PANEL_SIZE_ID_CONN 0V​
      The ones that are 0v,...
      02-18-2025, 02:13 AM
    • tech_guru
      Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
      by tech_guru
      Hello.
      I am having a disappointing motherboard repair with this laptop and I need your help.
      This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
      -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
      -PQ102 MDV1525URH
      -U17 AOZ1331
      -UE1 C8051F383-GQ
      -PU800 SY8032ABC
      -UI2 SY6288D20AAC
      -PU508 RT6220AHGQUF 7P=
      -PU100 TPS51225CRUKR
      -PU300 TPS51212DSCR
      Now, I get all the standby voltages, it turns...
      02-16-2024, 09:40 AM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
