PB easynote mh36 wifi adaptor disconnects & touchpad faulty
  • Motherfinboard
    • May 2020
    • 68
    1. This laptop connects briefly with wifi but after about 1 minute disconnects and will not find networks. Updated driver but still issue the same.
    2. Also the touchpad physical click buttons are not working,tried update drivers, could it be on the board and where to test?
    • 31248
    Re: PB easynote mh36 wifi adaptor disconnects & touchpad faulty
    the buttons - sounds like a loose or damaged cable.
    did you get it like that?
    • Motherfinboard
      • May 2020
      • 68
      Hi yes,it was been used with an external mouse. The mouse pad works but not the buttons. His it not 1 cable for mouse pad and buttons?
        • 31248
        very few are,
        normally the mousepad has a microcontroller on it that talks USB or PS2 to the motherboard,
        and either a seperate connector for the motherboard and button-pcb, or more usually a shared connector
        • Motherfinboard
          • May 2020
          • 68
          Buttons are separate and soldered to the main motherboard
            • 31248
            then check the cable for damage between the board and pad
            • Motherfinboard
              • May 2020
              • 68
              It's made in a way that 2 plastic buttons press directly to the board,no cable
                • 31248
                i mean between the motherboard and touchpad - the chip that reads the buttons is under the touchpad
                • Motherfinboard
                  • May 2020
                  • 68
                  Hi I am a bit confused now? the physical buttons are just plastic and press straight to the physical buttons on the motherboard don't think there is a chip where you said.
                  The touchpad works fine as a mouse apart from I cannot right click it's all left,it's the physical buttons below it that do not work at all.
                  This laptop is running vista if it makes a difference and WiFi connects once then it says no adaptor found/ no networks available.
                    • 31248
                    i'm saying the buttons are linked to the touchpad chip - if the cable isnt in straight or all the way it may not see the buttons
                    wifi - try a Linux livedisk and see if it works - that will tell you if it's software or hardware.
                    infact try that first
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Have you tested the switch works using a multimeter ?
                      • Motherfinboard
                        • May 2020
                        • 68
                        Hi will check out linux livedisk.
                        Not tested with multimeter, are you referring to wifi switch or touchpad buttons,and at what point do I test and volts or ohms?
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Touchpad button, ohms or continuity setting, test across the legs of the switch when you press it.
                            • 31248
                            btw, is it the original wifi card?
                            • Motherfinboard
                              • May 2020
                              • 68
                              Just about to use a Linux liveusb,once it boots do I just see if WiFi will work or does it scan the system and throw up any errors ?
                              Unsure if original WiFi card fitted.
                              Thanks again.
                              • Motherfinboard
                                • May 2020
                                • 68
                                I have WiFi working on Linux lite,but it drops after a few minutes,until I switch off the physical WiFi button and turn back on it connects. In Windows it drops after few seconds and will not come on back on until I reboot the system,and sometimes only getting local connection only,no internet.
                                Touchpad physical buttons still not working in Linux.
                                Thanks again
                                  • 31248
                                  well wifi card could be worn-out - it happens
                                  buttons - your gonna have to go into the machine and examine the switches and connecting cables
                                  • delaware74b
                                    • Apr 2009
                                    • 628
                                    It sounds like your wifi adapter is dying. I had the same thing happen in my Acer E5-571. It was a b/g/n/bluetooth card, Realtek iirc. This laptop is one of the last Acer's made with win7 during the switchover to WinHate. I uninstalled all old drivers, popped in an Intel ac7260 adapter with bluetooth and had zero issues since.
                                    I use the Acer as my primary laptop and automotive diagnostics with an OBDLink MX bluetooth adapter. It always connects to this Intel card. I had 25% success with the original card.
                                    Stupidity should be a crime, especially for drivers. I have NO patience for them.
                                      • 31248
                                      wifi chips get hot,
                                      if you use them a lot they burn out.
                                      routers and pci-cards have big heatsinks, but usb and mini-cards dont.
                                      i have kiiled atleast 5 usb wifi sticks in the past.
                                      • Motherfinboard
                                        • May 2020
                                        • 68
                                        Will try another WiFi card,and test the button pins on the board. Vista is causing issues as every website tell me the certificate is not safe and pages not loading probably in I.E. Chrome is a bit better but still getting issues with websites here too.
                                        May re-download vista or Windows 7 and see then .
                                        Thankyou
                                          HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-06-2024, 08:50 AM
                                        • JarzabekPZ
                                          HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                                          by JarzabekPZ
                                          I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                                          08-08-2025, 03:40 AM
                                        • Spudgun
                                          Why doesn't current just bypass faulty capacitors.
                                          by Spudgun
                                          Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                                          04-01-2025, 10:33 AM
                                        • Simonc123
                                          CH341A bios chip wont fit 1.8v adaptor holder
                                          by Simonc123
                                          Hi guys, I need a bit of help. I use a CH341A programmer, which is fine for 3.3v old-style bios chips. I need to reprogram some 1.8v chips, which are QFN type chips. I have the 1.8v adaptor for that slots onto the programmer, which does step the voltage down to 1.8v, but as you can see in the picture added, it doesn't fit in the IC holder.
                                          Please see the 4th picture that shows what looks like what should work for the QFN IC (highlighted in red). The issue is that the 8 pads on the programmer are too long and short out the IC. Is it a case of putting kapton tape over the center ground...
                                          03-09-2025, 08:54 AM
                                        • b-slayer
                                          Acer A317-53 need help to disable faulty onboard ram
                                          by b-slayer
                                          Hello.
                                          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                          - first one is to modify le bios to disable the onboard ram.
                                          - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                          so i found that my motherboard...
                                          10-12-2024, 03:46 AM
