nm-a273 no power
  • sonerpc
    • Oct 2015
    • 34
    • turkey
    nm-a273 no power
    greetings to all friends.
    My problem is nm-a273 lenovo device does not start.
    PQ301:SOURCE AND DRAİN 20V OK.BUT GATE 5V THİS NORMAL OR ANORMAL?
    PQ302:SOURCE AND DRAİN 20V OK.BUT GATE 5V
    5VALW AND 3.3VALW OK
    BİOS CHİP 1 AND 8. 3.3 V OK
    BUTTON 3.3V OK
    BUT NO START WHAT PROPLEM ?
    BİOS WRİTE BUT NO START...
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: nm-a273 no power
    PQ301/302 Gate voltage is ok as they are P channel mosfets. Try flashing known good bios first.
    • sonerpc
      • Oct 2015
      • 34
      • turkey
      thanks for the answer dude. i wrote a bios bbadcaps the result is the same
      • sonerpc
        • Oct 2015
        • 34
        • turkey
        When the dc power gives 20v, the white light is flashing in the motherboard
        • Techtiger
          • Oct 2014
          • 1601
          • france
          check for RSMRST# & EC_ON on SIO
          • Lvsitano
            Asus X532FL 3.2V at source and gate
            by Lvsitano
            I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
            First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
            I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
            First...
            06-26-2024, 02:13 PM
          • howardc64
            Macbook Dust-Gate Preventive Cleaning
            by howardc64
            Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
            Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
            https://www.ifixit.com/Guide/MacBook...leaning/177920
            10-09-2024, 10:10 AM
          • ash91
            DELL INSPIRON PS_ID PROPLEM AND FIX
            by ash91
            Hi
            I had a nice dell laptop yesturday,the proplem was it is not charging...
            i try another orginal charger with no luck also another battery no change either
            the famus massage that the ac adapter wattage in not reconize by the laptop always show at the boot
            in the bios the ac adpters is unkhown
            so it is a motherboard issu, first i download a boardview to know what i am abut to deal with
            then i extract the motherboard to start trace the voltage
            the 19.5 line was ok but the ps_id was 4.2v it shuld be 3.3
            the signal came from super io chip so that where...
            12-22-2023, 02:25 PM
          • irfan karatela
            MOSFET no voltage at gate Quanta G7HA DAG7HAMB8EO
            by irfan karatela
            I'm working on a HP Pavilion Laptop Model 15-eh1508sa that is missing 19v. I've looked at the schematics and want to know what conditions the ISL9238C checks before it enables the gate for MOSFETs PQ8200 and PQ8201,
            I havent found any shorts on the board.
            I get 19v at +PRWSRC but around 1.7v at the Drain of PQ8201(+vin)
            On Page 82 of the attachment. Link to schematic - https://www.badcaps.net/forum/troubl...ilion-laptop-p...
            01-20-2025, 07:15 PM
          • wagivem657
            Sharp LC-55LE643U, bad gate drivers?
            by wagivem657
            Just received a busted Sharp 55" Aquos (LC-55LE643U) from a coworker. He tried swapping all three boards (power, main, TCON) to fix the problem, but it had the same issue. He was kind enough to give me the TV and both sets of boards for free, so I can try to get it working for myself.
            Unfortunately, I think I may have made the problem (much) worse, but I'm interested to see if the original problem was fixable at all regardless...
            Pictures show the issues:
            1. shows what happens when you first turn the TV on. Well, kinda, the white column wasn't there at
            01-29-2021, 08:13 PM
