Gateway W350A with LCD light problem
  • manuel.it.solution
    • May 2020
    • 30
    • Ghana
    please i have these Gateway w350A a customer brought with the lcd light not working,i have changed the screen cable and inverter board but still no light comes on the screen when powered on.
    please can anyone be of help
    i don't know which one is the mobo number
    PWA P/N: 40GAB1800-F
    PCB P/N: 41-AB1800-F00G
    REV:F
    thanks in advance
  • peste
    • 12973
    • ROMANIA
    Re: Gateway W350A with LCD light problem
    Do you have a background image? .. if you check the display lamp ..
      • May 2020
      • 30
      • Ghana
      yes i have a background image and it even works on external monitor too
      • peste
        • 12973
        • ROMANIA
        then check the display lamp
          • May 2020
          • 30
          • Ghana
          i have tried with different screens and still the problem is there
          • Techtiger
            • Oct 2014
            • 1602
            • france
            what are the missing voltage on the LCD connector 30 pins test one by one & must be done with the screen connected try & request Schematic
              • May 2020
              • 30
              • Ghana
              please can someone help me with the schematic
                • 21219
                Schematic requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=41
                Don`t bother though,the schematic isn`t available.
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Cannot find the Schematic go through the pin count & test them all
                  • multimesut
                    Dell 2007FPB Yellow Light Problem
                    by multimesut
                    Hello friends,
                    A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                    11-13-2024, 07:00 AM
                  • Tom_x
                    HP Omen15 dc0001nh keyboard light problem
                    by Tom_x
                    Hi
                    I have this HP laptop, board: DA0G3DMBCE0 rev:E
                    The keyboard light only work, when i connect ac power supply(without battery), until the screen come with cmos checksum error. After this point light can't switch on. The first 5-6 seconds i can switch on/off light with FN+F4. When booing on, i can't switch on.
                    Keyb light controller Y59116, i think working, because receive i2c commands the firsr 5 seconds
                    I know schematic doesn't exist for this board
                    Someone know similar board, that use this rgb keyboard light controller?
                    regards
                    04-05-2023, 10:32 AM
                  • boyebaran
                    hisense 65k560 back light problem
                    by boyebaran
                    hi to all
                    tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                    in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                    please advise me tnx
                    05-20-2025, 07:11 AM
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • kity92
                    Edifier x3 Earbuds Blue Light Problem (Charging Problem)
                    by kity92
                    I ordered a Bluetooth earbud one and half year ago, and right earbud broke. The light that should have been red when you put it in the charging case started to turn blue continuously(which means earbud is not charging) and after 1 week the earbud completely died. I disassembled right earbud because the warranty finished. I diagnosed the battery was dead, so I charged it with TP4056 and revived the battery.
                    Right earbud is working now but I still didn't solve charging problem. I checked the charging box with a multimeter. There is 5V. I checked the headphone pins and they are working....
                    01-13-2022, 01:49 PM
