A1466 820-00165 fan spin, no chime vcore present
  • willumpie82
    • Oct 2015
    • 13
    • Netherlands
    I'm working on a rabbit-hole again, I have a 820-00165 board that has not been damaged (no liquid or other nasty stains).
    It came with the story that it runs but freezes randomly, when we looked at it at first it came to the disk selection and then frozen now it won't display or chime at all. I removed the SSD and wifi and inserted a USB drive, no changes.
    So opened it up removed the battery and when powering it on it gets fan spin but no chime and no image, looks brain dead to me...
    on visual inspection the board looks mint
    I Checked al the common voltage rails (mostly I just probe all coils) and look at the schematic if i see something weird.
    In this case they looked fine. also the two vcore phases rails are present (1.2v). I inserted a USB thumb drive and noticed the led on it to go on and off again constantly. the CPU gets a little warm as I would normally expect. Than I took my oscilloscoop and probed the 5v usb rail which was present and stable, I also probed the bios MISO line (slave out) and there seems to be data.
    to me it looks to be bootlooping but don't know why, (I checked all 820-00165 Rossmann videos but no clues)
    www.badcaps.net
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: A1466 820-00165 fan spin, no chime vcore present
    Inspect board under microscope for any hint of liquid or physical damage/knocked off component.
    VCore should be 1.7V so double check that.
    • willumpie82
      • Oct 2015
      • 13
      • Netherlands
      Hi
      The vcore rail and is is 1.8v
      also verified all the other rails, all OK
      ppbus_3gh = 8,57
      PPBUS_S5_HS = 8,57
      PPBUS_S5_HS_OTHER = 8,57
      PPDCIN_G3H = 17,94
      PPDCIN_G3H = 17,94
      PP3V42_G3H = 3,42
      PPVRTC_G3H = 3,34
      PP5V_S5 = 5,109
      PP5V_S4RS3 = 5,11
      PP5V_S0 = 5,11
      PP3V3_S5 = 3,34
      PP3V3_S4 = 3,34
      PP3V3_SUS = 3,34
      PP3V3_S3 = 3,34
      PP3V3_S0 = 3,35
      PP3V3_S4SW_SNS = 3,34
      PP3V3_S0SW_SSD = 3,34
      PP3V3_S4_TBTAPWR = 3,34
      PP1V8_S3 = 1,79
      PP1V2_S3 = 1,20
      PP1V05_SUS = 1,05
      PP1V5_S0 = 1,51
      PP0V6_S0_DDRVTT = 0,6
      PP1V05_S0 = 1,049
      PP1V05_S0SW_PCH_HSIO = 1,049
      PPVCC_S0_CPU = 1,80
      when assembled + ssd = current is 665mA
      www.badcaps.net
      • Lukira
        • Feb 2021
        I have a board with exact same issue. Have you found a solution??
        When I got the computer I noticed that the bottom case had a dent right on top of the fan and the fan housing was bent preventing it to turn. I bent back the housing and turned on the computer.
        It booted normally but the screen was dark and the brightness button wasn't working.
        At first I thought it was freezing because the cpu was overheating because the fan wasn't spinning but no... after that it would turn on only sometimes and when it did, it would freeze.
        After that it didn't booted anymore. I have vcore phase 1 and 2 and cpu gets a little warm, fan spins but no chime or image.
        The board was very dusty but no corrosion at all.
        • platinumsteel
          Macbook Pro 2012 CPU Vcore Present No Post
          by platinumsteel
          Hi guys hoping you can help me solve this issue. I have 3x 820-3115 boards. One fully working with CPU Vcore 0.8v and posting which am using to compare against the other 2...The other 2 has CPU Vcore stuck at 1.12v and doesn't drop down to 0.8v.
          PPBUS_G3H is 8.56v and all other rails present. They both do not post or give picture and no caps lock. Hoping anyone may have experience with this and advise me on a few things to try. So far the only thing i tried was a few different bios for this board and nothing changed same behavior persists I have the original backups saved.Thx...
          01-08-2025, 04:18 PM
        • zpi
          A1466 820-00165 Chime and freeze on osc loading, with battery no chime.
          by zpi
          Hey guys, so i have here really strange board...
          These steps needs to be done to get a chime board starts to load osx but freezes with no loading bar:
          1.Disconnect battery
          2.P+R+CMD+OPT to pram reset
          3.After only 2-7 atempts to pram reset i get chime.
          4.Then i get chime allways, but if i connect battery, then boards stops to chime till i make steps from 1 to 3.
          Board looked very clean, no liquid damage. Already replaced isl6259 and SMC, good known battery. Still same problem, sometimes turned off board without battery uses 0.03...
          11-10-2020, 04:42 PM
        • rex98
          JS47A/JS57A/JS77A NM-E531 onboard ram disable
          by rex98
          hi i have this laptop IdeaPad 3 15ABA7 this is the boardview https://www.badcaps.net/forum/troubl...90#post3740490
          nm-e531 i tried all kinds of bios editing and it doesn't work. it doesn't have schematic but it has boardview with board ID details in it.
          maybe you could help me how to shift these resistors to disable its onboard ram.
          this is is the presents and not presents...
          10-07-2025, 03:39 AM
        • lapfix
          Lenovo Air 15ITL NM-D211 missing RSMRST !
          by lapfix
          Lenovo Air 15ITL.
          NM-D211
          This laptop won't power on , when power supply is on it takes 0.001 , button trigger on it becomes after a couple of seconds 0.061 amp..and nothing
          No heating (Of COURSE) , no short to GNd at all coils present , 3/5 valw is present , 3/5 vl present.
          With the power plane , at state 4 +1.8VALW and +3ALW_PCH must be present but no one due to enable signal is missing .
          when button trigger on , 3v dow to zero than 3v , the super io send BTN_OUT#_R to pch but no rsmrst ..0v.
          i follow his line , no short .
          10-21-2025, 05:53 AM
        • moscast
          No +VCORE in acer TravelMate TMP2510
          by moscast
          Hi everyone
          I have a problem with this laptop that won't turn on.
          The +VCORE is not present and doing some measurements on the ISL95859 I notice this:
          VIN present 19.5V
          VCC present 5V
          VR_ENABLE present 3.3V
          PWM_A present 2.5V
          FCCM_A not present
          PWM1_B present 2.5V
          PWM2_B present 2.5V
          FCCM_B not present
          PWM_C present 0.32V
          FCCM_C present 5V
          In these conditions should the ISL95859 works and therefore enable the FCCM_A and FCCM_B pins or do I have to check other lines for it to be enabled?
          Maybe the...
          04-06-2024, 01:49 AM
