Macbook Pro 2012 CPU Vcore Present No Post
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Hi guys hoping you can help me solve this issue. I have 3x 820-3115 boards. One fully working with CPU Vcore 0.8v and posting which am using to compare against the other 2...The other 2 has CPU Vcore stuck at 1.12v and doesn't drop down to 0.8v.
    PPBUS_G3H is 8.56v and all other rails present. They both do not post or give picture and no caps lock. Hoping anyone may have experience with this and advise me on a few things to try. So far the only thing i tried was a few different bios for this board and nothing changed same behavior persists I have the original backups saved.Thx
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Okay so thought I’d post how the issue was kinda solved think it might help someone.i read on the forum where someone had a similar issue and piernov mentioned that it can be a ram issue with these model boards..So I decided to try the other ram slot and low and behold the vcore dropped too 0.8v and it posted with picture. Both boards are posting now with the ram in the second slot .I tried cleaning out the first slot but that slot refuses to work on both boards.So will leave it at that for now.Just glad both boards are working. Thanks again piernov and the entire Badcaps community.
    • mon2
      • 14683
      https://www.youtube.com/watch?v=58dFwz4AttM
      • platinumsteel
        • May 2019
        • 234
        • Trinidad&Tobago
        Thanks a lot for the video. I inspected all my pins as in the video and all of mine are good and has a solid connection. My issue may be a little different. Only on closer inspection under the scope inside the top memory slot. I notice 1 pin is damaged. On both boards in the top slot 1 pin is kinda damaged. Really difficult to repair. Got nothing to lose will try to fix it and maybe see how that goes. But i'm just glad to at least know what the problem is with both boards.
        • mon2
          • 14683
          https://www.youtube.com/watch?v=1Zf_ADyjS9k
          • Rezendes
            Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
            by Rezendes
            Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
            I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
            The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
            05-10-2024, 02:18 PM
          • korben_dallas
            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
            by korben_dallas
            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
            MY QUESTION:
            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
            02-14-2024, 12:23 AM
          • bastien
            OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
            by bastien
            It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
            This is the new database for FlexBV
            it's optimized to work with it
            by using board ID has Default name, give us the opportunity,
            to use other diode board data with sibling board or family board
            I Merged the whole data (optimal)
            A2991 A2992 M3 -> -> 2 Entries diode data M1
            A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
            A2442 A2485 A2779...
            03-18-2025, 08:03 AM
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • ResoluteHawk
            MacBook A1706 No Power; 20v present on board
            by ResoluteHawk
            I have a Macbook A1706 that won't turn on. It did have signs of liquid damage under U7650 so I replaced the chip. No changes.
            I then went to measure a see if PP3V3_G3H is present on R7009. It is indeed present at 3.4v.
            However, PPBUS_G3H on F7000 measures 1.1v without the battery installed.
            A USB-C amp meter initially shows 5v in but then goes up to 20v. 0 amps are present as the board is not turning on. No fan spin either.
            02-07-2023, 10:47 AM
