DELL 3521 LA-9104P getting 5 volts on VIN SECTION instead 19 volt
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Dell 3521 la-9104p getting 5 volts on vin section instead of 19 volt
    dell 3521 La-9104p getting 5 volts on VIN SECTION on the ACP ACN
    But when i remove IO getting 19 volt on VIN ( ACP ACN )
    what is the problem
    Without IO 19 volt is ok
    WITH IO getting 5 volt on VIN
  • lapfix
    • Mar 2020
    • 2757
    • my workshop
    Re: DELL 3521 LA-9104P getting 5 volts on VIN SECTION instead 19 volt
    What do you mean by ACP ACN ! why you remove IO !
    What's the voltages on PQ101 all pins
    • qayyum786
      • Aug 2018
      • 1959
      • INDIA
      Thanks for your reply
      I got it
      CPU is short
        1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
        by sam_sam_sam
        I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
        This metal lathe has a weird motor setup it has a soft start motor with a β€œY” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
        12-29-2024, 07:18 AM
      • piernov
        Reminder: rules and organization of this section
        by piernov
        Activity on this forum has been increasing steadily and the workload for the moderation team as well in order to keep the place clean, so please make an effort to keep it organized.
        I've been deleting more and more posts that make a mess, so take a minute before posting to make sure you make a proper request/offer.
        Reminder about the rules and the organization of the "Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals" section.
        This section and its subsections are about the following classes of devices:
        • Desktop computers
        • All-in-one
        03-31-2023, 06:17 AM
      • nabilgo
        dell 3521 la9104p
        by nabilgo
        hey all
        i have dell 3521 la9104p he work only on battery and when i remove the battery and try o turn it on with charger he work for 2 seconde...
        06-10-2021, 05:51 AM
      • gabri2211
        external hd Seagate, broken down the +12 volt and USB 3.0 SATA board
        by gabri2211
        Hi to all 😎
        I'm looking for any useful information to repair this interface (I have attached the image).
        On this board I read E3215-1215A_4D.
        This is the small plate inside the HD enclosure that allows to connect a 12 volt power supply, interface the disk with a USB 3.0 socket and is connected to the HD with the SATA connector.
        If any of you have found a burnt or short-circuited component in a circuit like mine​, if you have useful diagrams for the repair, or even better a description for the tests at the test points, I would be very grateful.
        in particular...
        11-12-2024, 08:08 PM
      • jasonbay13
        Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
        by jasonbay13
        it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
        PU200
        pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
        pin 8 vreg3 = 0v
        pin 13 en = .2v
        pin 1,6 entrip1,2 = 0v
        b+ and b++ = 19.5v
        +5valw = 0v & 25+ohm to ground
        +3valwp = 0v & 25+ohm to ground
        i cleaned the board up just a little and can get more pics.​
        where should i be looking? thx...
        09-25-2025, 10:54 PM
