Dell N5050 ( Short on Cpu power supply chip )
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi There
    Had this laptop with no power after injecting power at the 19v power rail this was the chip that got hot it was shorted after removal I now have the power light on the laptop the ic is RJK03B9DPA but I'm struggling to find this chip is there any compatible chips that I can use..
    Your never to old to learn
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: Dell N5050 ( Short on Cpu power supply chip )
    You can take it friom any doner mobo , it's N-channel...but before you replace it make sure that the short is gone
    • piernov
      • Jan 2016
      • 4439
      • France
      This is from a high current multi-phase buck converter. You CAN'T just put a random MOSFET in there.
      You need the exact same model.
      If it's impossible you need to find a very close match (several parameters to take into account: package, N-channel, Vds, Id, Rdson, timings and maybe capacitance…) and replace the MOSFETs from the other phases so that they are all matched.
      You also need to replace the MOSFET driver at the same time.
        • 21936
        ebay https://www.ebay.co.uk/itm/5pcs-KO3B...p/193029553896
        • khelane
          • Apr 2015
          • 172
          • xxxx
          one question:
          if we can't find it can put match mosfet with parametre:
          30 V, 22 A, 10 mΩ
          or other parameters:
          how much important this parameters for replacing mosfet for cpu or gpu power circuit? or other circuit?
          tnx
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
          • DynaxSC
            ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
            by DynaxSC
            Hi
            I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
            08-04-2025, 12:20 PM
          • ed1i
            Dell Inspion 7610 bios chip
            by ed1i
            Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
            01-16-2025, 02:14 PM
