Macbook pro 820-2530 troubleshooting
  • King_Jorg
    • May 2020
    • 8
    • Spain
    So this system is not turning on, no light on charger when plugged in.
    I start troubleshooting and i get 0v everywhere.
    Replaced r6905, c6990 and c6999 now i have 3.6v and 17.2v on both sides of r6905.
    D6905 has 3.6v on pin 1 but 2.7v on pin 5.
    Q7050 has 1v everywhere less pin 4 which has 0.22v.
    Pin 4 is CHGR_BGATE which comes from U7000.
    U7000 has:
    0v on DCIN,
    4v on ACIN,
    0v on VDD,
    1.7v on PP3V42 G3H.
    U7000 CHGR_DCIN comes from D7010 wich has 0v on DCIN side but 17.22v on the other side.
    I upload schematics see if someone can give a clue.
    Thanks in advance.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Macbook pro 820-2530 troubleshooting
    Resistance to ground on PP3V42_G3H?
    • King_Jorg
      • May 2020
      • 8
      • Spain
      Lmao i promise i checked that..
      I get 0.. Looks like I have a short now.
      Ill try to hunt it and update woth news thanks man
      • King_Jorg
        • May 2020
        • 8
        • Spain
        Macbook pro 820-2530 short on PP18V5_G3H
        So this system has 17.2v on PP18V5_G3H with 0 resistance to ground.
        Removed R6905.
        Still shorted
        R7062 gets 7v instead of those 17v. Removed and board still shorted.
        Fuse on that line is ok..
        Any ideas?
        • piernov
          • Jan 2016
          • 4435
          • France
          Re: Macbook pro 820-2530 short on PP18V5_G3H
          Remove the fuse and check which side the short is on.
          • King_Jorg
            • May 2020
            • 8
            • Spain
            Thanks piernov,
            Short is after fuse, on pin 2.
            • King_Jorg
              • May 2020
              • 8
              • Spain
              Is it normal to get 0L on multimeter when measuring resistance to ground (diode mode red on ground, black on path ) when circuit has no power?
              I get 2.6 when there's power on that rail
              • piernov
                • Jan 2016
                • 4435
                • France
                Resistance to ground must be measured without any power.
                • King_Jorg
                  • May 2020
                  • 8
                  • Spain
                  So im getting 0L on pin1 of that fuse when no power.. What 0L means then?
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    O.L. means near infinite resistance.
                    I'd recommend you to learn how to use a multimeter before trying to fix a Macbook logic board.
                    After that, all the basic troubleshooting steps are covered by Louis Rossmann on his Youtube channel. He also made a document to learn the basics that you can find in his video description.
                    • King_Jorg
                      • May 2020
                      • 8
                      • Spain
                      Im doing it man im watching all of them..
                      Im just trying to learn dude dont have to be mean.
                      Well after building again all the paths i have no shorts.
                      I have u7000 not getting power through DCIN cause pp18v5_g3h is not getting through d7010..
                      Is it possible to skip a diode?
                      I dont get why power is not going through it.
                      Everything else is looking fine.
                      PD. Replay if you can help but if you going to tell me to watch Louis Rossman videos im already doing it for 2 months thanks!
                      If for whatever the reason is you dont know how to help me or you dont want just dont reply.
                      Thanks in advance.
                      • luckydip
                        • Aug 2016
                        • 159
                        • uk
                        whats the reistance between pin 17&18 and 27&28 on U7000?
                        voltages on pin 1,3?
                        check resistance of r7040
                        PPBUS_G3H voltage?
                        • envym
                          by envym
                          Hi everyone!
                          06-27-2025, 08:54 AM
                        • tobeend
                          Bypass mdm macbook m2 ventura
                          by tobeend
                          1. RESET MACOS WITH IPSW
                          a. Power off MacBook, press and hold the power button to enter Recovery
                          b. Open Disk Utility, remove Macintosh HD
                          c. Reboot, connect to the network to Activate Mac.
                          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                          e. Release the other keys, but keep holding the Power key for another 10 seconds
                          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                          05-26-2023, 07:18 AM
                        • SarcasticOP
                          General question about MacBook power rails for repair.
                          by SarcasticOP
                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                          • PPBUS_G3H (12.6V-12.8V)
                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                          • PP3V42_G3H (3.42V)
                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                          • PPVRTC_G3H (3.3V)
                            • This
                          12-12-2024, 05:50 PM
                        • obelix24
                          A2941 Macbook air 15” - 5V 0a
                          by obelix24
                          I’m working on one macbook air 15” m2 that was water damaged.
                          keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                          i’ve put macbook in shelf and order new screen so i can fully repair it.
                          Now i got the screen and macbook stays at 5v 0a.
                          i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                          i don’t have schematics so i don’t know where to start can someone help me?...
                          03-27-2025, 01:19 PM
                        • geolangston
                          2019 macbook a2141 backlight troubleshooting
                          by geolangston
                          Hello, I have a 2019 macbook a2141 with no backlight. video image is visible with flashlight but no backlight. All the associated circuitry is located on the back side of the logic board. I've removed the logic board and display and have them connected together on the bench so I can probe the back side of the board. I'm applying power through a usb-c port attached to the logic board but I'm not sure how to actually boot the logic board. I tried attaching the power button and that didn't work. I also have the fans attached and they are not spinning. If anyone can help me with this setup I would...
                          05-21-2023, 04:18 PM
