A1398 820-3332-A unable to restore
  • magneh
    • Apr 2014
    • 619
    • Portugal
    Hi everyone.
    Got this logic board, turns on , chimes, I can boot and choose pen drive for OSX install, but hangs up everytime near the bar loads.
    Same thing with internet recovery.
    Run built in diagnostic test, quick test no error.
    Any one had similar issues?
    What could this be related with?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: A1398 820-3332-A unable to restore
    Screen is cracked, always describe history of laptop as it can give a lot of hints…
    Also has the EFI been messed with? Did you try to run ASD? Boot in verbose mode? Never goes further even after waiting 10 minutes?
    Note that this board has an common problem with solder joints of U8900 cracking.
    • magneh
      • Apr 2014
      • 619
      • Portugal
      Salut Piernov!
      Sorry. Yes cracked screen. Built in ASD runs OK in both short and long test.
      Check U8900 joints, and seemed fine. Still re flowed them, no change.
      EFI IC seems factory soldered.
      Strange behaviour.
      Tried high sierra and dos dude's catalina usb Stick, the bar blocks as in previous photo.
      Does not go further.
      If I wait like 20 mins, I see screen going black and fans spinning.
      I wake up the device, but I dont get the bar again. Machine like reboots again.
      Same thing with Internet recovery.
      Strange right?
      • magneh
        • Apr 2014
        • 619
        • Portugal
        Any ideas?
        CPU VRMs?
        Bad PCH/GPU?
        • piernov
          • Jan 2016
          • 4439
          • France
          You should use ASD (both EFI and OS mode if possible) not AHT. It gives much more detailed information.
          It's not really the symptoms I'd except but maybe there's an ME region issue. I'd try a known good dump with clean ME.
          • magneh
            • Apr 2014
            • 619
            • Portugal
            Salut Piernov,
            Thanks for your inputs.
            In ASD 3S155 ran the full test and had 1 error in battery condition, but not related with the loading issue, as I tried it without battery and still the same.
            I will try to run the ASD OS mode and also check if I can get a good dump to flash the bios also.
            Ill update when possible.
            Merci
            • yheriatovych
              A2338 820-02020-A 5V, no screen, unable to revive/restore
              by yheriatovych
              Hi. I need some help troubleshooting the issue (which is a bit odd to my limited experience) with the A2338 Macbook.
              Initial symptoms:
              One day the laptop refused to wake up (as it seemed at first), spinning the fan on full blast, with no picture on the screen.
              Force rebooting didn't help. To check if it boots at all I connected the external display and surprisingly it booted to the system, and I was able to log in to the system.
              However, I noticed that it was in some weird state:
              • The fan was still blasting at full speed. It's blasting even when the system
              01-31-2024, 10:22 AM
            • Max Leo
              Model A1398 (EMC 2909) adapter unable to read or detect
              by Max Leo
              i connect with this adapter unable to read or detect do i have to do something or short something to read the bios...
              10-30-2025, 07:58 AM
            • T4H
              820-02016 - No Trackpad / Keyboard - Unable to restore via AC2
              by T4H
              Im facing keyboard and trackpad issues (no function) on an A2337 (820-02016 / MacBook Air M1).
              I have already tried the following:
              • Replaced the flex cable (between logic board and trackpad)
              • Tried another top case (same issue)
              • Replaced UT330, UT355, UT310, UT360 and UT365
                • IPD_SPI_EN_CON = 0.596
                • IPD_SPI_EN = 0.316
              Is it normal that "IPD_SPI_EN" is always 0V?
              And when it try to restore the MacBook via AC2 (DFU Mode) I get the following error message:
              What does AC2 error 16383 mean?
              03-08-2024, 05:46 PM
            • tyl85
              HP AIO 23- G111nl - Unable to restore bios by usb drive
              by tyl85
              Hi, i have this 23'' AIO similar to a big notebook
              Black screen no backlight
              POWER LED:ON HDD led blnks very rapid
              First question:
              4 internal jumper, how to use?
              1) CLR_PW
              2) BOOT BLOCK
              3) BOOT WRITE
              4) FDO
              Second question when i attemp to flash bios by usb drive jumpering BOOT_BLOCK
              i hear 8 long beeps then usb drive flashing, then hdd light blinks rapidly e i got screen on HP "unable to open bios image file" then goes off
              what i can do?
              tried 2 different usb drives
              2 bios file...
              07-14-2023, 02:42 AM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
