Lenovo G710 Very weird GPU issue
  • KvnTM
    • May 2018
    • 434
    Hello Friends,
    I'm puzzled about this laptop.. It has a dedicated Nvidia 820m GPU and BSoD's
    randomly. The GPU works fine with 3D Mark and FurMark. Memtest reported no
    issues and the CPU is fine. So far so good.
    Now the weird part begins:
    Furmark reports the GPU as a GT710m. GPU-Z as 820m and the Nvidia Control
    Panel sometimes as 820m and sometimes as 720m. I can't install the official
    drivers from nvidia for either the 720m or 820m. It always says that the installer
    can't find a compatible GPU. But Windows installs the 820m drivers by itself.
    When running 3D Mark or Furmark no BSoD's appear. But it instantly crashes
    when closing the internal "benchmark" in GPU-Z with
    VIDEO_SCHEDULER_INTERAL_ERROR. This typically tells me that the GPU is
    dying. But no other Benchmark causes issues, even when running it for hours.
    One thing I noticed: When stressing the CPU it thermal throttles to around
    0.8GHz after some time. The frequency does not normalize after that, even when
    the CPU sits at 50C. It just stays at 0.8GHz. Restarting the Laptop has no effect
    either. Only completely shutting it down once restores the normal clocks.
    I'm confused to hell... Did someone experience this behavior?
    Screenshots were taken via TeamViewer. I don't have physical access to it at the
    moment but I can do remote tests.
    Sidenote: I analyzed the minidumps of all crashes and it was never caused by the
    Nvidia driver. Always something random kernel or windows related. Only when
    forcing it to crash via the GPU-Z benchmark it fails with the usual nvxxxxx.sys file.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo G710 Very weird GPU issue
    Entry-level GPU are often the exact same GPU rebranded over several generations so it's not surprising to see different names. Here GPU is GF117 and apparently it can be 620M/625M/630M/710M/720M/810M/820M. The official NVidia driver package for any of those should still install properly.
    Maybe you have a power related issue rather than GPU issue itself.
    • KvnTM
      • May 2018
      • 434
      Thats pretty stupid but hey Nvidia isn't known for logical product names, right?
      Anyways.. I'd also imagine that it is a power issue. But why doesn't it crash when everything is under stress? Temps are also irrelevant. Sometimes it crashes instantly after powering on and sometimes after hours.
      Kinda reminds me of the Late 2013 15" Macbook Pro's without a dGPU...
        • 21877
        What bios version does it have. 8ECN95WW has a Vbios update
        https://download.lenovo.com/consumer...s/8ecn95ww.txt
        Update N15V-GM VBIOS to N15V_GM_75_17_84_00_FF.
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          What times do BSODs appear during ordinary usage of the laptop?
          What does happen if you restart the laptop just after a BSOD?
          • KvnTM
            • May 2018
            • 434
            I‘d assume my mom (her laptop) didnt update the BIOS so i assume it’s the first released one. Will do that! I havent thought about that..
            Pretty much randomly but seems to be only happening when the gpu drivers are loaded. Didnt occur while running memtest overnight. She mostly browses the web on Chrome or does Text editing stuff.
            The GPU-Z benchmark crashes it instantly when closing it. It does not crash while stressing the GPU or CPU.
            It works normal after restarting. Minidumps are pretty much useless since it crashes at random things which are not related to the GPU. Only the GPU-Z thing crashes the nvidia drivers.
            • KvnTM
              • May 2018
              • 434
              Updating the BIOS didn't fix the issue.
              I still can't install the official drivers for it. I can only install a very old driver package from 2015.
              I disabled hardware acceleration in Chrome a few days ago and it seems to be more stable now which makes sense because it doesn't use the GPU anymore.
              • emestee
                • Dec 2019
                • 228
                • Bulgaria
                I googled for curiousity and it appears the discrepancy between 820m and 710m being reported is normal - you can find any number of screenshots of furmark showing the same thing for other people.
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  If you test the GPU using a live bootable CD, you may get better error messages. this is because of the fact that no OS will be involved between the test software and the GPU.
                  • KvnTM
                    • May 2018
                    • 434
                    Any suggestions on a live CD with nvidia GPU support and benchmarks? Usually linux distros dont come with nvidia or any discrete GPU drivers iirc.
                    • SuperJames
                      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                      by SuperJames
                      This one's a weird one, and still unsolved despite it having gone back to Dell once.
                      Specs
                      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                      Backstory
                      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                      10-23-2023, 04:09 PM
                    • ugamazing
                      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                      by ugamazing
                      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                      04-10-2024, 08:06 AM
                    • lukkihapsi
                      Asus Vivobook X515JA Weird Boot Issue
                      by lukkihapsi
                      Asus Vivobook X515JA Laptop
                      Issue :
                      Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                      Tried :
                      Cleaned inside for dust, applied fresh thermal paste. No Change!
                      Removed keyboard, Trackpad, fingerprint sensor. No Change!
                      Removed Internal SSD. No Change!
                      Updated BIOS to latest version. No Change!
                      Removed battery and pressing power button for 1 minute. No Change!
                      Weird Part :
                      Upon turning laptop ON, screen lights up - stays black,
                      I...
                      07-07-2025, 12:07 PM
                    • tommygun26
                      Hp 6510b weird issue
                      by tommygun26
                      Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
                      02-26-2023, 06:00 AM
                    • Spider1211
                      Weird but interesting issue with DELL 3542 (intel mb 13269-1)
                      by Spider1211
                      Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
                      Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
                      Backstory:
                      Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
                      Power supply draw:
                      Voltage: 19.40V
                      Amp draw: 0.006 - 0.007A
                      Amp draw...
                      04-07-2021, 03:21 PM
