Asus X550LN screen glitches when flexing board
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Hello Have this Asus X550LN that have glitches on screen when flexing board and even turn off. I try to isolate flex point and it looks like it is bad ball under processor.
    Have this model discrette GPU run from start, or it first start on integrated GPU?
    I try to chceck if it is not bad ball under GPU as it is close to processor
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • TheDando
    MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
    by TheDando
    Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
    10-28-2024, 06:59 PM
  • DynaxSC
    ASUS STRIX Z490-F GAMING - No POST, stubborn board
    by DynaxSC
    I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
    The situation looks like this:
    After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
    1. RTC oscillates normally (32.768KHz).
    07-08-2022, 05:45 AM
  • ShadowAi12
    ASUS ROG STRIX B550-F GAMING — Board not powering on properly
    by ShadowAi12
    I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
    • The board enters a "ready to power on" state after plugging in the PSU.
    • Pressing the power button increases power draw.
    • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
    Measurements:
    (taken after pressing the power button, while the board is attempting to start)
    • H_SKTOOC#
    06-11-2025, 01:05 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
