MBA 820-00165 Pulses S0 State then off again every 3sec.
  • lazaro.089
    • Jun 2014
    • 79
    • Mexico
    No liquid damage, just a little corrosion on R6125 and R6120 but cleaned it.
    Something strange, when I test on diode mode on F7140 (PPBUS_G3H) it beeps for half a second then impedance gets higher.
    If I reverse the proves it shows me low impedance but not low enough to beep.
    Maybe a Short? or ISNS resistor?
    When powered on PPBUS_G3H is 8.6 stable. And tested PP3V3_S0 and PP5V_S0. And it pulses to right voltage and then 0V. It does this every 3 seconds or so.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: MBA 820-00165 Pulses S0 State then off again every 3sec.
    CPU VCore probably pulsing too — confirm.
    SPI ROM communication issue can definitely cause this. You already spotted corrosion on R6120 and R6125. There's more. Dirt on J6100, U6100, U6101, damaged/corroded resistor, broken trace, probe point…
    • MobileXT
      • Oct 2012
      • 191
      check the high current sensing resistors if they read by specs.
      • junda
        MacBook Air A1466 820-00165-A 5V Rail Pulses (on & off)
        by junda
        hi, i also have the same (P5V_S4RS3) MacBook Air A1466 820-00165-A 5V Rail Pulses (on & off) The strange thing is when I kept machine for 1 day and connect the power It powers on with Chime and booots half way with Apple logo and stuck. at that time when I power of and try power up Fan spins for few seconds and goes off with no P5V_S4RS3 and also the P5V_S4RS3 EN pulses on and off with 3,24 V. Plezzz doesn any one can help me
        08-26-2024, 09:54 AM
      • DoOm86
        Unknown IC heating up on a Hp looping every 3sec
        by DoOm86
        Hello. Notbebok Hp 15s-fq2004nl, board DA0P5MB38A0, turns on and then off after 3 seconds, in loop. Powering on with full battery, or with original charger, or both, same result. With power supply and everything unplugged, same.
        No core voltages... but no shorts was found (31 ohms the coil of the cpu) . Bios ic sends data and has the right voltage in those 3sec.
        3v ldo present, 3v and 5v just in those 3 sec.
        This IC is mad hot (70 degrees) after pressing the power button, no info was founded about it. On the IC is written "W384" and "2823D". No board schematic...
        04-12-2024, 04:13 PM
      • mferna14
        by mferna14
        Hi all , I am working on a Apple MacBook Air A1466 820-00165-A logic board. The problem was no back light & all was working fine. I replaced the Backlight chip but still no display & now it does not even turn on. I replaced with a known good back light chip assuming the soldered chip was shorted. But still no luck. Now I measure voltage rails. 3.3V is perfect but 5V Rail Pulses (on & off). TPS51980A, 5V ENABLE pin 4 P5VS4RS3 EN R also fluctuates on & off. 5V comes & then shut off again. This happened continously. I checked for any short to ground, but none. When I check for...
        01-04-2022, 04:42 PM
      • dclass-pro
        HP Notebook With Strange Defect Does Not Turn On
        by dclass-pro
        Hi Guys, I have a HP DAX12AMB6D0 REV.D with a strange defect, that is on the 2nd mosfet on the power supply, the gate voltage does not reach 25V but pulses... if I try to touch some capacitors with my fingers, the voltage on the gate reaches 25V and the notebook turns on.
        I have already tried to change the charging connector, PU1 and PQ20 but I have not obtained any result, the problem still persists.
        Here are the voltages that I find ON PU1:
        Pin 1 - Pulses between 2 and 3v
        Pin 2 - Pulses between 2 and 3v
        Pin 3 - Pulses between 2 and 3v
        Pin 4 - Pulses between...
        01-31-2025, 08:27 AM
      • powerblackout
        820-4924-A Missing PM_SLP_S4_L
        by powerblackout
        mystery board no history!
        no corrosion or liquid damage anywhere.
        green light on charger, 24ma power draw.
        PM_SLP_S5_L 0,0v pulses on SMC_ONOFF_L
        PM_SLP_S4_L 0.0v pulses on SMC_ONOFF_L
        PM_SLP_S3_L 0.0v pulses on SMC_ONOFF_L
        PM_SLP_S0_L 0.0v pulses on SMC_ONOFF_L
        PM_SYSRST_L 0.016v no pulse on SMC_ONOFF_L
        PM_S0_PGOOD 0.00v pulses on SMC_ONOFF_L
        SYS_PWROK pulses on SMC_ONOFF_L
        PPBUS_G3H 12.67v
        PP3V3_S5 3.3v
        PP3v3_S4 0.0v
        pch_intruder_l 3.3v
        PM_RSMRST_L 3.3v
        PPVRTC_G3H 3.34v
        RTC_RESET_L...
        01-07-2023, 11:25 PM
