Intermittent WDC Harddrive ?
  • bianchi77
    • Jun 2016
    • 1121
    Dear Member,
    My WDC 250Gb Harddrive, sometimes can not be detected by BIOS ?
    What's the issue with it ?
    Can it be a power supply issue ? I'm using 430W with double VGA
    2xSSD 2x HDD
    65W CPU
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Intermittent WDC Harddrive ?
    i had some of that problem, and apparently it's a hard disk failure. even on usb box it give same error... motor start... then ges off then on again and then it works, but i wont put any important data on it as sometimes do that loop on of more then once.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      More likely, corrosion on the HDD board!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        today i heat up the big chip on hard disk board, and looks like it power on and stay that mode without going on on -off then on
