820-2915 2010 Macbook Pro 15" Doesn't Detect Battery in OS
  • KappaDev
    • Feb 2019
    • 41
    Hello, I have a 2010 Macbook Pro 15" (Logic board 820-2915).
    Battery is not detected in the operating system, does not show any battery symbol in top bar (on lastest MacOS High Sierra). System info shows battery not installed. Green light on charger and does boot.
    I've tested several known good working batteries but no luck. Tried disconnecting battery indicator and rebooting but did not seem to help. Battery indicator does not show any lights (with or without power applied). The batteries I have to test with have been sitting for quite some time so they are most likely depleted (so I'm not sure if the board will run off battery).
    SMC/PRAM reset attempted but also didn't seem to do anything.
    No short to GND on SMBUS_SMC_BSA_SCL 6.49v or SMBUS_SMC_BSA_SDA 6.50v
    PPBUS_G3H is 12.57V
    Any suggestions? Boardview and schematics are attached.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-2915 2010 Macbook Pro 15" Doesn't Detect Battery in OS
    Are you 100% sure your batteries are good and compatible with the machine?
    Any damage to the battery connector on the board or the traces around it? Does it look like it makes good contact with the battery?
    R6950 good?
    This is a 2011 model btw.
    • KappaDev
      • Feb 2019
      • 41
      R6950 good?
      No noticeable damage near connector. Continuity seems to be good between traces and battery pins. R6950 seems good, 10kOhm. Plugged into another mac battery shows fine (0% charging).
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • gboone
        820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
        by gboone
        Hi, I was given this laptop by my uncle who said:
        • It would occasionally shutdown if not plugged in
        • battery had been replaced
        • touchbar would "strobe"
        I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
        After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
        BUT
        When powered off, it would at some point have a...
        01-27-2025, 09:12 AM
      • mferna14
        MacBook Air A2681 battery problem after Screen Replacement
        by mferna14
        Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
        12-06-2024, 08:10 PM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • leonemax81
        Macbook a1707 820-00281 Battery no Power
        by leonemax81
        Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
        08-23-2024, 09:24 AM
