Macbook Air A1466 2015 logicboard 820-00165 turns on BUT no screen and chieme (sound)
  • rietel
    • Apr 2020
    • germany
    I would appriciate very much if someone is more agile than me to solve my current issue with a logicboard of MB AIR 2015 13", #820-00165
    The board is powering up, the fan starts spinning, all voltages are present, green/orange light is on but I don't hear the chieme, the screen is not showing any signs and the external screen isn't working either.
    There was a little liquied damage on the reset chip U5110 which I have cleaned. I took it also off and cleaned it underneath. Also some damaged copper trace I fixed too. The cap C5120 I replaced as well. One side had corrosion. But all this didn't help! There is no obvious sign of any other damage caused by the liquid.
    My test setup looks as follows: logicboard, audio/power PCB, power adapter, battery, ssd with installed OSX, external monitor on display port.
    When the board starts I noticed the fan stop spinning shortly after a few seconds then it starts running again for always. If I only have battery connected to the board the fan runs about 10s and stops for about 2s then restarts for 10s again and again. If I connected a working board the fan never stops spinning with or without power adapter.
    Does anyone has an idea in which direction I could look at? The issue is really hard to detect. I hope SMC or GPU are not causing the problem.
    I am very thankful for anyone who can help!!
    THX
    Mario
  • aazjo
    • Jun 2020
    • 9
    Re: Macbook Air A1466 2015 logicboard 820-00165 turns on BUT no screen and chieme (so
    Mario,
    Can you post voltages of the different rails like they do in this thread (https://www.badcaps.net/forum/showth...ighlight=U5110)? That will help to narrow it down.
    Thanks,
    Joe
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Could be a bios issue.
      • piernov
        • Jan 2016
        • 4435
        • France
        Any history apart from liquid damage? CPU VCore present? PLT_RESET_L?
        To diagnose the board you only need a Magsafe, DC-in board (FFC is not required to be connected), fan and obviously main logic board.
        If there was liquid damage on U5110 there may be damage somewhere else… do a thorough visual inspection near SMC, SPI ROM, J6100…
        • luckydip
          • Aug 2016
          • 159
          • uk
          Voltage on pin 5 and 8 of U5110 correct?
          Any usb activity?
          I've had a few of these - a nightmare tbh. Start off by a thorough U/S clean. Could be anything from bios, corrosion around smc/U6100 tracks/U1950 and there were a couple of mysteries I never solved! I usually leave these to the side and come back to them from time to time if I'm bored.
          • yura8
            Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
            by yura8
            Hi there! I have not so usual situation...
            I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
            My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
            P.S. If you have else any ideas about repair, or you had a similar...
            12-20-2024, 02:31 PM
          • dicorato
            Macbook air 2015 - A1466 - PM_SLP_S5_L is 3.1v good?
            by dicorato
            I'm trying to diagnose this a1466 board, I'm pretty new with this, but I checked the signals up until PM_SLP_S5_L, which is at 3.1v. Is it a valid level for this signal?
            11-18-2023, 08:25 AM
          • psdavid65
            Macbook Air A1466 820-3437-B Booting Problem
            by psdavid65
            I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
            06-20-2024, 12:27 AM
          • twonk9098
            Macbook Pro mid 2015 battery required to boot?
            by twonk9098
            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
            This model has the newer trackpad which is not clickable when turned off.
            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
            12-10-2024, 06:51 PM
          • Strolch
            MacBook Air A1466 2015 no Power on
            by Strolch
            I have a MacBook Air 2015 2.2GHz i7 A1466 820-00165-A. It had worked normally. Now it doesn't start anymore. When Magsafe is plugged in, the LED will turn solid green and then orange. I can also do an SMC reset. But you can't turn it on.
            03-18-2022, 11:02 AM
