Macbook air 2015 - A1466 - PM_SLP_S5_L is 3.1v good?
  • dicorato
    • Nov 2023
    • 5
    • Italy
    I'm trying to diagnose this a1466 board, I'm pretty new with this, but I checked the signals up until PM_SLP_S5_L, which is at 3.1v. Is it a valid level for this signal?
  • mon2
    • 14659
    Re: Macbook air 2015 - A1466 - PM_SLP_S5_L is 3.1v good?
    https://logi.wiki/index.php/User:Pie...sing_SLP_S5.23
    • mon2
      • 14659
      https://www.it-tech.com.au/mac-q-a/p...-l-timing/amp/
      Remove all power. Measure the resistance to ground of the 3v3 rail used as the pull up. If the rail is not 3v3 then check its resistance to ground to see if it is under excessive load.
      • dicorato
        • Nov 2023
        • 5
        • Italy
        I measured PP3v3_S5 is at 3.3v. Resistance to ground is at 55 ohm.
        • mon2
          • 14659
          That is a low resistance. Be sure there is no power to the board during the resistance check.
          What is the 820-**** number of your logic board?
          • dicorato
            • Nov 2023
            • 5
            • Italy
            No power connected during the resistance test. 820-00165-A
            • dicorato
              • Nov 2023
              • 5
              • Italy
              Any idea what to check next? Check ICs on the 3v3 rail by removing them?
              • mon2
                • 14659
                PM_SLP_S4_L​ = 0v9 which is considered a logic LOW. This signal should be a logic high = ~3v3 if all is well.
                Review the same webpage and go through the 11+1 sequence of checks:
                • yura8
                  Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
                  by yura8
                  Hi there! I have not so usual situation...
                  I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
                  My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
                  P.S. If you have else any ideas about repair, or you had a similar...
                  12-20-2024, 02:31 PM
                • psdavid65
                  Macbook Air A1466 820-3437-B Booting Problem
                  by psdavid65
                  I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                  06-20-2024, 12:27 AM
                • twonk9098
                  Macbook Pro mid 2015 battery required to boot?
                  by twonk9098
                  I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                  The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                  This model has the newer trackpad which is not clickable when turned off.
                  At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                  If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                  12-10-2024, 06:51 PM
                • Strolch
                  MacBook Air A1466 2015 no Power on
                  by Strolch
                  I have a MacBook Air 2015 2.2GHz i7 A1466 820-00165-A. It had worked normally. Now it doesn't start anymore. When Magsafe is plugged in, the LED will turn solid green and then orange. I can also do an SMC reset. But you can't turn it on.
                  03-18-2022, 11:02 AM
                • Dale65
                  MacBook Air 13” 2015 A1466 820-00165
                  by Dale65
                  I have a MacBook Air 13” 2015 A1466 820-00165 that started out booting to apple logo and would try to load then would just reboot . Now the fan is the only thing that will work but it spins and stops and maybe once every so often will stay spinning. The battery will charge and turn green from orange . The hard drive and processor will get pretty hot . I really can't see anything burned out and it never had liquid damage . I tried all the hot keys that where suppose to get it running with no success. Any help or ideas would be greatly appreciated.
                  T...
                  10-13-2021, 06:33 PM
