Hp CQ62 SIO problem EC_USB_PWR_EN
  • NConstantinou
    • May 2017
    • 351
    • Cyprus
    i have hp PM_A_HPC_S_MV_MB_V1 MOTHERBOARD.
    the 3.3/5v voltage regulator is working.
    i do not have the 5v on usb.
    following the schematic i notice that from ITE8502 ,EC_USB_PWR_EN goes to usb chip APL3510 EN pin directly which suppost to be 3.3v, i get 0.05v and then goes to 0 and then back to 0.05v.
    Can i give 3.3v from some other place instead of changing SIO ic!
    • 21880
    Re: Hp CQ62 SIO problem EC_USB_PWR_EN
    If the APL3510 is shorted why would you run 3.3V from somewhere else. Its an N channel mosfet, test it out of circuit
    • NConstantinou
      • May 2017
      • 351
      • Cyprus
      Thanks for your reply,
      APL 3510 is not short. The voltage 3.3v is delivered from SIO pin 88 ec_udb_pwr_en to a resistor and then to pin 4 of alp3510.
      As I mentioned when having the probe of multimeter on pin 4 I see that shows 0.05v,then 0v and back to 0.05v.
      I tried resolve ite8502 but still the same result.
      The power on lamp is blinking and laptop does not turn on.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        measure pin on KBC.voltage and resistance to ground
        • NConstantinou
          • May 2017
          • 351
          • Cyprus
          On keyboard connector pins 27,32 i get 0v.
          resistance to ground 5.43K but i do not get any shorts
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            keyboard connector?
            KBC is SIO or EC
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              Did you got schematics ! post it.
              what's the value of the resistor betwen pin 88 and pin 4 of alp3510 ! is it the same as the schematics !
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • lazaro.089
                Asus Zephyrus M16 / GU603ZW problem
                by lazaro.089
                Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                CPU: Core i9-12900H
                Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                08-26-2025, 06:33 PM
