HP 650 1858-100 need info R1104 smd resistor code
  • Japanac
    • Aug 2014
    • 95
    • Serbia
    HP 650 1858-100 need info R1104 smd resistor code,the resistor is burned so no mark is visible.
  • classicandy
    • Apr 2018
    • 309
    • Nigeria
    Re: HP 650 1858-100 need info R1104 smd resistor code
    Hi, I suspect its 2R2 that is written on it. 2R2= 2.2 ohms.
    The board I have with me currently is HP 655, but at that similar area, it is 2R2 on it.
    • Japanac
      • Aug 2014
      • 95
      • Serbia
      Yes it is 2R2
      • Japanac
        • Aug 2014
        • 95
        • Serbia
        does anyone have a service manual for this motherboard
          • 21960
          Ask in the schematic requests section,and use the forum search,one might be posted already
          Schematic Requests https://www.badcaps.net/forum/forumdisplay.php?f=41
          • mikey5791
            Need help to replace burned resistor in 350w atx psu
            by mikey5791
            Hi to all forum members,
            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
            12-26-2024, 04:55 AM
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • MidnightRoller
            Can a resistor lose resistance after hot air?
            by MidnightRoller
            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
            02-02-2022, 11:46 PM
          • artvandalai
            What resistor ohm will work better to repair this waterpik?
            by artvandalai
            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
            01-05-2025, 04:10 PM
