asus k53s (motherboard k53sv rev 3)
  • pippostino
    • Mar 2020
    • 10
    • italia
    Hi everyone, I have a question to solve on an asus k53s laptop (motherboard k53sv rev 3), in essence I have about 14.4 v on the battery connector, after about 5 minutes that it is charging (measured with battery inserted). Are 14.4v normal or exaggerated? I state that I opened the PC because it did not charge the battery, I found a burnt resistance of 0.020 ohm that connected with the battery connector and which I assume is part of the charging circuit. The IC of the circuit is the BQ24740. I can't find the PC service manual. Now I wonder how can the correct functioning of the charging circuit be verified and also without battery? It's possible? Another detail that I noticed is that the charge indicator LED is always orange and never green and then goes off after about 30 minutes, every now and then it flashes briefly and after 1 hour it switches off completely; the voltage measured on the battery is 12.19 volts. The charge indicator icon says to replace the battery. I apologize for taking a little longer. I attach the photo of the circuit where I replaced the resistance. Thank you !
    Ps: I'm afraid to put a new battery, I wouldn't want to ruin it!
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: asus k53s (motherboard k53sv rev 3)
    That Resistor is not burned it’s a CLR current limited Resistor that is not your problem what is the Voltage you get in Battery connector all pins with battery with out Battery
    • pippostino
      • Mar 2020
      • 10
      • italia
      Hi techtiger, thanks for the prompt reply, then, first of all, the limiting resistor was burnt and I replaced it; without battery pack I have no voltage, with battery pack, the voltage varies from a minimum of 12v to 14.5v and at that point also stops the charge of the pc but the battery does not fully charge. the question I ask myself is this: is it normal for the voltage to rise to that value? shouldn't it be limited to 12.6v? another detail is that the charging indicator goes impulsively, that is, it turns on and off, it does not always stay on, consequently the LED is on, there is voltage, the LED is off, there is the residual battery voltage (about 30% of the total voltage). thanks again and good day.
      forgive my english now i am using google translator
      • pippostino
        • Mar 2020
        • 10
        • italia
        the battery connector has 9 pins, starting from the negative side, the first two are the negative, on the next pin (let's call it 3) there are 0v, on the next (4) there are 3.24v, oscillating at 3.27v, on the next ( 5) same situation (these should be given and clocked) the next pins (6 and 7) are 0v, and on the next pins (8 and 9) there is the battery voltage: 12.19 v if it is not charging , Oscillating 14.4v [as I explained before] if it is charging. This situation is with battery connected. If there is no battery, on the connector I have the following condition:
        pin 1 and 2 = 0v
        pin 3 = 3.26v
        pin4 and 5 = 3.29v
        pin 6 and 7 = 0v
        pin 8 and 9 = + 1.26v
        tanks.
        • pippostino
          • Mar 2020
          • 10
          • italia
          NB: Correct: pins 4 and 5 should be DATA and CLOCK
          • kropotkin
            Oscilloscoopper
            • May 2018
            • 48
            • Republic of Belarus
            If you can not find schematics - just use commonly accessible datasheet for charger
            This resistor serves for current sensing of either current cunsumption by whole laptop, either for battery charging/discharging only (there are two separate).
            Which way resistor was burnt - actually, it had infinite resistance? In this case breackage of this current sensing resistors causes loss of charger's functionality.
            Sometimes it can go further on...
            • pippostino
              • Mar 2020
              • 10
              • italia
              hi Kropotkin, what that resistor is for is known; I don't know how it burned. The resistance had infinite value, therefore completely open;
              • kropotkin
                Oscilloscoopper
                • May 2018
                • 48
                Hi! If it was originally of black color, not green which is on photo now, than those black ones tempt to mecanically loose the contactof solderingto their top along one of sides. Meet such defects few times on Asus and Samsung boards.
                If you know for what this resistor serves - you can imagine that upon breakage of it all the voltage of battery/adaptor will be applied to current-measuring inputs of charger. Consequencess may be different, one photo in preview post - is Asus1215b where such black schunt due to bad contact killed newly installed charger IC in already assembled device. Later on when I met such situation I've studied it under microscope - it do was the case
                • kropotkin
                  Oscilloscoopper
                  • May 2018
                  • 48
                  I have few such bords, they have green resistor, probably it is not the case. Any case, "aximum difference voltage ACP–ACN, SRP–SRN, AGND–PGND –0.5 to 0.5V" - says TI datasheet. Hardly it stay alive
                  • pippostino
                    • Mar 2020
                    • 10
                    • italia
                    Hi, the original resistor was green. I am interested in knowing a 3 cell 10.8 / 11.1v battery, if the voltage I find is excessive or it should be maximum 12.6V. thanks and how to check the operation without battery .thanks . original battery is A32-K53.
                    • kropotkin
                      Oscilloscoopper
                      • May 2018
                      • 48
                      I can not clearly understand which kind of problem do you have at the moment. Use AIDA software, there you can see some numbers of power, measured with charger for accu charging rate and battary state. Give them to us.
                      My suggestion - if something is wrong with indication/charging - you will deal with partially defective bq24740 in you case, as it "eated" some voltages ~100 times higher than it shoul accept at current-measuring inputs. You have possibility to try to replace it?
                      • pippostino
                        • Mar 2020
                        • 10
                        • italia
                        I do not have the possibility to replace it because they are not available in Italy, they only come from the UK and China and with the current situation I am afraid that certain types of imports are blocked. however I did a test, I opened the battery pack and disconnected the positive and negative battery, I powered the PC by inserting only the electronics in the battery compartment; measuring the voltage between + and - where the battery should be connected and the voltage is actually high, there are about 18v. thank you
                        • kropotkin
                          Oscilloscoopper
                          • May 2018
                          • 48
                          If problem is only lack of IC - you may find it on many other boards - fromsome old HP Probook 4515, 4525, compaq 615. Think you can find easily, these boards mostly defective on AMD chips, so it's 99,99% that charger IC's will be Ok.
                          • pippostino
                            • Mar 2020
                            • 10
                            • italia
                            Thank you Kropotkin for the indications, but unfortunately I have nothing among the disused cards in my possession. Thanks for your time
                            • dhenion
                              Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                              by dhenion
                              I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                              The original board was:
                              ASUS X510UNR REV 3.0 A
                              The replacement board is:
                              ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                              It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                              01-30-2024, 01:45 PM
                            • cope
                              Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                              by cope
                              I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                              Some history:
                              Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                              As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                              Now, with a new battery the system will start up and run off...
                              05-13-2024, 09:40 AM
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • rob777
                              Asus TUF won’t run off battery
                              by rob777
                              I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
                              I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
                              Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
                              Thanks....
                              05-27-2025, 07:07 PM
                            • glovecaps
                              Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                              by glovecaps
                              I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                              My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                              The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                              11-25-2024, 04:23 PM
