Pm_a_hpc_s_mv_mb_v1 5v ic no output
  • NConstantinou
    • May 2017
    • 340
    • Cyprus
    Dear all
    i have the above m/b with 3.3/5v voltage regulator SN0608098 IC.
    i have the 3.3v but not the 5v.
    i have replaced ic but still no 5v output.
    on pin 17 VBST I HAVE 4.76v.
    on pin 16 LL1 and pin 15 DRVH1 I HAVE NOTHING.
    DOES ANYONE HAVE ANY IDEA!!!!!!!!!
    THANKS
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Pm_a_hpc_s_mv_mb_v1 5v ic no output
    Remove a Pad of the _+5V ALWS & Check the Resistance to GND upload the Schmatic
    • kropotkin
      Oscilloscoopper
      • May 2018
      • 48
      • Republic of Belarus
      If it's Foxconn SAFINA, than VALW channels has separate controls, look page 32 of schematics. While 3.3V run automatically, 5V need permission from EC. What is on pin 14?
      How do you feed MB - can tell overall current consumption by MB at 19V when powered off?
      • Techtiger
        • Oct 2014
        • 1602
        • france
        First are you missing +V5A on PJ543 ? If so check pin 7 if you get LDO after pin 12 Voltage?& the 249K is good or not, check VBAT PJ14 and the Voltage on D1 PQ850?
        • NConstantinou
          • May 2017
          • 340
          • Cyprus
          by removing PAD PJ25 the resistance to GND is 1.1KΩ
          The resistance to GND is 1.1kΩ
          Pin 14 is EN1, reads 120mv.
          MB is feed with bench power supplyat 2.5A
          By removing the pad PJ25 i get resistance to GND 1.1KΩ
          Yes i am missing +V5A.
          Pin 7 has 4.75V. i checked on PR174.
          PJ14 has 18V
          • Techtiger
            • Oct 2014
            • 1602
            • france
            which side of the PJ251.1KΩ and other side of the Pad ? what is resistance to GND PJ24 ?
            • Techtiger
              • Oct 2014
              • 1602
              • france
              PJ14 has 18V
              remove PCE18 220uf Cap and check resistance to GND Buzz Mode M-Meter PJ25 both side of the pad , PR170 249K is correct or not ?
              • kropotkin
                Oscilloscoopper
                • May 2018
                • 48
                So, You have no permitiion from EC to start +5VALW. What the symptoms do you have now from board - any reaction to PRWSW?
                There might be few reasons of EN1 missing - even wrong BIOS or dead SB820. Remove RTC battery and make thermotest fo it with hot air, 300C fo 30sec.
                • NConstantinou
                  • May 2017
                  • 340
                  • Cyprus
                  The resistance to GND with+PCE19 is 1.28KΩ.
                  On PJ25 the resistance to GND betwwen GND and + PCE19 is 1.28ΚΩ also
                  PJ25 and PJ 24 Pads are disolder.
                  • NConstantinou
                    • May 2017
                    • 340
                    • Cyprus
                    PR170 measures 170.8 KΩ instead of 249k without removing cap.
                    should i remove cap!
                    the PCE18 cap is setting on a base. when i tried before to pull out cap
                    one leg was destroyed. i am afraid to remove it unless if i try to disorder from mb
                    • NConstantinou
                      • May 2017
                      • 340
                      • Cyprus
                      • NConstantinou
                        • May 2017
                        • 340
                        • Cyprus
                        Board indicates that there is NO short.do you suggest to remove RTC and heat SB820 to 300C for 30seconds!
                        • kropotkin
                          Oscilloscoopper
                          • May 2018
                          • 48
                          at least it takes 1 minute instead of desoldering capacitors. Same capacitor should be placed back. Did you try to flash bios first?
                          Look at page 5 of schematics - setting of EN_1 for 5VALW - marked as the first event during platform initialisation, before - only SB and EC are working. Importnt is that AC_OK from charger must be apropriate.
                          • NConstantinou
                            • May 2017
                            • 340
                            • Cyprus
                            i will try to find adaptor and flash bios and i will come back to you
                            thanks
                            • Techtiger
                              • Oct 2014
                              • 1602
                              • france
                              You have to replace that cap Pce18 later, most Probably you didn’t apply heat correctly for the moment don’t replace PR170 you have to find out why EN1 Not getting Required, check if it’s not short to GND or preheat as Kropotkin Have point out
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                What voltage you get SIO pin 4 74 127
                                • FrancescoV
                                  Onkyo HT-R390 no sound output, video output ok
                                  by FrancescoV
                                  Good morning everyone,
                                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                  The firmware reported is the following:
                                  M:1.00/11107BLP
                                  D:?.??/????????
                                  O:1.00/11107AL
                                  The DSP firmware given the question marks seems corrupt.
                                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                  05-11-2025, 02:59 AM
                                  NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                  I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                  I bought this from an eBay seller but unfortunately they only had one
                                  I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                  I bought three of from them to also make battery packs with this output power limit in mind
                                  I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                  04-23-2025, 05:50 AM
                                  Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                  by momaka
                                  Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                  So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                  09-19-2021, 08:44 PM
                                • CoppellTVRepair
                                  Troubleshooting PFC with SPC1012T not raising output
                                  by CoppellTVRepair
                                  It has been a long while since I posted here to ask anything....hope you can help.
                                  I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                                  I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                                  03-09-2025, 10:38 PM
                                • flibidy
                                  Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                  by flibidy
                                  I have here a Magnum IA.100 which belongs to my parents.
                                  The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                  Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                  What Ive done........
                                  01-01-2025, 01:26 PM
