Asus K550V no powered on
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Hy , this laptop is dead , there is 19V only on the first mosfet
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus K550V no powered on
    Voltage on all pins 1&2 Fet (D S G )
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      Fet 1 near connector on D 19V S 0V G 0V and on the Fet 2 all 0V
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Your 2 Fest are N channel fets gâté need 24V to Bypass the voltages. you have to check the two MOSFETs one of them is short or faulty there is another way to bypass the voltage to see if the MB working or not
        • Fabbrone
          • Jun 2015
          • 158
          • italy
          I checked with a multimeter, on Fet 1 between D and S ther is high impedance , on the Fet 2 there is 0,7 ohm
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Take it out of the MB and test it again after removing check the resistance to GND R010 CLR next to the 2nd Fet , I will explain after how to bypass the voltage to see if the MB working or not
            • Fabbrone
              • Jun 2015
              • 158
              • italy
              I removed the fet 1 is between D and S there is high impedance also inverting the terminals. Between R010 and gnd high impedance
              • Techtiger
                • Oct 2014
                • 1602
                • france
                High impedance ? How many Ohms?
                • Fabbrone
                  • Jun 2015
                  • 158
                  • italy
                  On the Fet pin D-S 2.5Mohm, also between R010 and ground 2.5 Mohm
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    thats fine do a last test put the multimeter in DIODE range do the same test 1st & 2 fet (S D G) and the R010, remove the 1st fet out of the MB to test , do you have a power LAB ? if the 1st fet is fine to find out the MB is working or not put a sold wire from Drain of 1st fet to Source of 2nd fet pads you can leave the second fet out of the MB for the moment but with a powre LAB it's easy to fine out any short
                    • Fabbrone
                      • Jun 2015
                      • 158
                      • italy
                      if I try the first unsoldered fet with the multimeter in diode mode it works by putting the positive on the D and negative on the S is open but if I touch G and S here it is enabled and now between D to S is 0.
                      Yes I have a power lab but to try I have to unsolder the second fet too?
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        With the power lab first apply 1V 3A to the S of 2fet the is connected to the R010 it’s you CLR if nothing get heat or no short in lab increase the power up to 19V gradually & power the MB
                        • Techtiger
                          • Oct 2014
                          • 1602
                          • france
                          in N-Channel Fet black probe to S Black probe to D Red you should get value of 50-600 if you reverse probe no value or high value , S Red Probe G black probe no value or high value, D to G no Value or high value
                          • Fabbrone
                            • Jun 2015
                            • 158
                            • italy
                            OK Ok tried to power it and turn on the video immediately goes into the bios correctly. Retrying the first unsoldered fet with the probe R on D and probe N on S multimeter no value if I invert the probes there are 2.2 mega ohms. Probe R on D and N on G no value if I invert 2.3 mega ohms. If I put probe R on S and N on G there are 30 ohms
                            • Techtiger
                              • Oct 2014
                              • 1602
                              • france
                              Ok I will look in to it but do not power the MB any more if any EMI electromagnetic effects the MB will die
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                Find out the number of the charging IC
                                • Fabbrone
                                  • Jun 2015
                                  • 158
                                  • italy
                                  I don't have the schematics , maybe a photo of the main board can help you
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    What is the number of this IC
                                    • Fabbrone
                                      • Jun 2015
                                      • 158
                                      • italy
                                      It's uP1565p
                                      • Techtiger
                                        • Oct 2014
                                        • 1602
                                        • france
                                        It's uP1565p
                                        Not this one it's the RAM Régulateur the 1st 2 letters start BQ24XXX Search
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
                                        • MicroSMD Lab
                                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                                          by MicroSMD Lab
                                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
                                        • someonenotyou
                                          ASUS G513R - cannot remove MOSFET
                                          by someonenotyou
                                          Hi.
                                          I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
                                          I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
                                          Of course, I did not force it, but tried to lift it up with tweezers.
                                          Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
                                          10-10-2025, 11:05 AM
