Toshiba A-300 notebook does nothing
  • diegito11
    • Jul 2016
    • 94
    • España
    hello companions this portable A-300 has arrived without ignition, when I open it I find that q801 that in its pins 1,2 and 3 measure me 20v and in pin 4 its gate also measures me 20v which I think it should not be and in pins 5,6,7 and 8 0v so there is no voltage over there. I changed the mosfet in case it was malfunctioning but still the same
    Looking over I see nothing burned, I doubt the IC U803; I have measured pin 12 VDC and the 20v enter, pin 3 and 4 and pin 24 00.6.
    I think it's not working well.
    I pass the scheme of the plate that is pt10g 6050a2171501 mb a03
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Toshiba A-300 notebook does nothing
    Resistance to ground on +VBAT?
    • Techtiger
      • Oct 2014
      • 1601
      • france
      The 1st Fet P channel Gate should be less than 10V Check the voltage on ACDRV pin 2 U803
      • diegito11
        • Jul 2016
        • 94
        • España
        la resistencia en escala de 200 ohm es de 68,4
        The resistance in 200 ohm scale is 68.4
        • diegito11
          • Jul 2016
          • 94
          • España
          el pin ACDRV 2 U803 da 20v lo mismo que en pin4 deQ801 al estar comunicado.
          en fuente allways no tengo ni 3v ni5v ya que no pasa el voltaje del principio y no tengo voltaje en el resto de la placa.
          the ACDRV 2 U803 pin gives 20v the same as in pin4 of Q801 when communicating.
          In source allways I have neither 3v nor 5v since the voltage of the beginning does not pass and I have no voltage in the rest of the board.
          • Techtiger
            • Oct 2014
            • 1601
            • france
            English pl
            • diegito11
              • Jul 2016
              • 94
              • España
              Sorry I didn't realize.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                is this +VBAT resistance?? If so your +19V rail is shorted.
                • diegito11
                  • Jul 2016
                  • 94
                  • España
                  then I rule out U803 that is wrong?
                  • diegito11
                    • Jul 2016
                    • 94
                    • España
                    Well I checked by removing Q801 and I connected it by measuring pin4 the gate and it still gives me 19v so U803 ic BQ24721C is wrong.
                    I wanted to ask you here I have several ic that I do not know if they will be compatible with this, I pass the list and tell me:
                    TPS51125RG
                    MAX17435
                    Bq24703 the latter I think if not?
                    • diegito11
                      • Jul 2016
                      • 94
                      • España
                      TPS51125RG
                      MAX17435
                      https://bdfixforum.blogspot.com/2016...uivalents.html
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3577
                        • slovakia
                        please dont judge anything when u cannot understand function of BQ
                        read datasheet of it
                        what is ACDET, VCC, ACDRV#, VREF5, CHGEN# voltages?
                        • diegito11
                          • Jul 2016
                          • 94
                          • España
                          I said that because a tv electronica told him about it and he told me that, I don't know if it is not the same case in tv electronics.
                          I pass the measures:
                          pin 5 ACDET 00,9v
                          pin12 VDC 20v
                          pin 2 ACDRV # 20v
                          pin11 VREFS 0v
                          pin 1 CHGEN # 00,1v
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3577
                            • slovakia
                            as first u see in datasheet
                            https://cdn.badcaps-static.com/pdfs/...0f5cb1cd24.pdf
                            , u dont have ACDET signal, which detects power adapter
                            next u dont have VREF5
                            • diegito11
                              • Jul 2016
                              • 94
                              • España
                              What does that mean, that U803 is wrong?
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3577
                                • slovakia
                                measure ACDET circuit. R814 awith R815 works as voltage divider
                                u have whole schematic and datasheet. try to figure it out
                                  Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                                  This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                  09-06-2024, 05:27 AM
                                  Toshiba Satellite A300-1RZ Specification for Upgrade or Repair
                                  This specification for the Toshiba Satellite A300-1RZ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1RZ boardview and A300-1RZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Satellite...
                                  Toshiba Satellite Pro A300-1MK Specification for Upgrade or Repair
                                  This specification for the Toshiba Satellite Pro A300-1MK can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1MK boardview and A300-1MK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                  Toshiba Satellite A300 A300-14S Laptop Schematic
                                  Quanta BL5S Santa Rosa - Rev 1A...
                                  11-01-2024, 07:49 AM
