lenovo 330s-15ikb
  • riki_22
    • Jun 2014
    • 72
    • italia
    lenovo 330s-15ikb
    hi, in this laptop i found a mosfet in short, the serigraphy name is J8 GUC, in the position mainboard Q8902, can anyone help me identify this mosfet?
    i can't find schematic.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: lenovo 330s-15ikb
    Search the schematic EG521 EG522 EZ511 EG721 NM-B451
    If it’s a MOSFET it’s either N or P channel
    • Draconian
      • Feb 2019
      • 4
      • United Kingdom
      Could you provide more information on how you've tested that the mosfet is short.
      Also what type of mosfet are we talking about as your post suggests there is little information available online however with a little extra info like what the mosfet is doing and what channel type it is you can likely make a substitution for something else that'll do the job.
      • riki_22
        • Jun 2014
        • 72
        • italia
        removing the mosfet from the mainboard source and drain is in short, it is the second mosfet in series after dcin for power.
        and I thought to change it with P0903BEA, because in some asus models they do the same job.
        • Techtiger
          • Oct 2014
          • 1602
          • france
          check the voltage on the 1st fet Gate with out the second Fet less than 10V its P channel above 22V its N channel
          • riki_22
            • Jun 2014
            • 72
            • italia
            Thanks a lot, in this case the gate is 25v, which mosfet N equivalent do you recommend?
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Any Fet with 30V N channel
              • coasterghost
                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                by coasterghost
                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                System Hardware:
                Processor: AMD Ryzen 7 PRO 5850U
                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                09-08-2025, 10:46 PM
              • ebyte64
                Lenovo IdeaPad 330 laptop mosfet issue
                by ebyte64
                Good day everyone.
                I have been scratching my head with a Lenovo laptop I got in today.
                The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                Would anyone...
                06-27-2023, 10:19 AM
              • Grafnus
                Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                by Grafnus
                Hey there,
                first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                Specs:
                • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                • CPU, GPU, RAM work fine (not involved in the Problem)
                So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                Now I noticed...
                08-06-2025, 11:54 AM
              • m0jo1103
                Need help.... Lenovo L340-15IRH mosfet missing!
                by m0jo1103
                Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
                05-19-2025, 07:13 AM
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
