HP EliteBook 8760w BIOS Chip Location?
  • midihead7
    • Dec 2019
    • 14
    Greetings to you all. I need to replace or re-flash the corrupted BIOS chip on an HP EliteBook 8760w (Quad Core version). The BIOS was corrupted or erased by a nasty virus and the laptop will not power on at all so the Win+B key combination doesn't work to do the emergency restore of the BIOS. Where is the BIOS chip specifically located on the motherboard? I think that it may be the 8-pin chip located near the external battery port and memory slots on the bottom of the laptop (as seen in the picture) but I am not certain. I apologize that I am not yet very experienced with reading motherboard schematics so your advice and guidance would be most welcome.
    The numbers on that chip start with MXIC MX25L64046EM2I-12G which correspond to the BIOS schematic I found (screenshot also attached). The number on the board next to the chip is U10060 which also corresponds to the BIOS schematic screenshot. I've included a closeup shot of the chip on my motherboard for comparison.
    If this is not the BIOS chip, could someone please post a photo that clearly indicates the actual location of the BIOS chip on the motherboard? Thank you very much. You help is deeply appreciated.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: HP EliteBook 8760w BIOS Chip Location?
    U10060 Is your BIOS chip 8MB The Chip has been already removed by another technician
    you need a special tool to flash BIOS
    • midihead7
      • Dec 2019
      • 14
      Thank you very much for the confirmation. I am aware of the tool needed to flash the BIOS and have already ordered it.
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Make sure 3V VCC is available in pin 8 if not set dead
        • midihead7
          • Dec 2019
          • 14
          So you are saying that if pin 8 doesn't have 3V VCC available then the BIOS chip is dead and should be replaced?
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Set dead means the MB will not power up, just check if you get 3V with out pressing the power pin 1/8 should get +V3AL this is a LDO from Tps51123 regulator pin number eight provides this voltage
            • midihead7
              • Dec 2019
              • 14
              Thanks for the advice. When the battery or power supply is connected, the fan kicks on for a few seconds along with all of the LEDs (with nothing on the display) then shuts off and continues in this loop until power is removed. The BIOS on a second identical 8760w was affected by the same virus and exhibits this exact same behavior.
              • Techtiger
                • Oct 2014
                • 1601
                • france
                Most likely BIOS fault MB tries to read the bios rom, fails and loop
                • midihead7
                  • Dec 2019
                  • 14
                  When requesting a full BIOS dump (in the BIOS Requests thread) for the 8760w, is it necessary for me to specify the exact series build of my motherboard?
                  My motherboard has a label on it near the DIMM slots that shows this model number:
                  652509-001 SYS BD 4 DIMM
                  When looking for schematics for the 8760w, I have seen that there appears to be at least two version builds of the 4 DIMM board (there could be more I suppose):
                  AEROSMITH_6050A2438301_PVR-Build_A01_20110311_4-DIMM_MB
                  AEROSMITH_6050A2438301_MV-Build_A03_20110826_4-DIMM_MB
                  Since my laptop won't power on, I don't have an easy way to verify exactly which board I have.
                  The BIOS updater provided by HP is model specific so the update appears to cover all versions of the 8760w motherboards. Are the 8760w full BIOS dumps (like those shared in this forum) compatible with every build of the 4 DIMM board or do I need a full dump specific to the build of my board?
                  Your advice is deeply appreciated. Thank you.
                    by SMDFlea
                    Bad...
                    09-02-2021, 04:40 PM
                  • hotcrossedbuns999
                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                    by hotcrossedbuns999
                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                    3. I could only locate two chips that look like bios chips. Could someone verify this
                    01-03-2025, 12:32 PM
                  • BMCappelletti
                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                    by BMCappelletti
                    Long story short:
                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                    - gave the computer to his son a couple years later
                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                    (seems like the story was not that short)
                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                    01-08-2025, 07:27 PM
                  • thxd43
                    Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                    by thxd43
                    Hello, first of all, excuse me, I am using the translator, English is not my native language.
                    I have a Lenovo ideapad 330S - 14IKB laptop.
                    The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                    02-23-2023, 08:37 PM
                  • inck243
                    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                    by inck243
                    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                    The BIOS...
                    07-25-2024, 09:17 AM
