Laptop Motherboard Repair
This topic is closed.
  • Pyr0Beast
    • Feb 2009
    • 406
    #41
    Re: Laptop Motherboard Repair
    If one of those chips is shorted it will definitely heat up a lot. And they do go bad. But that stuff is obvious - rail is down.
    I have never given much thought about the post card as I don't really need it. But it is cheap.
    Reading reset is useful.
    I don't have the scope capable of measuring the output of modern PLL's in range of 200MHz or more so I don't bother (much) with that (also, can't find a replacement either if I find it faulty)
    90% of all damaged stuff is power related. I stick to that.
    On and off would seem like a power faliure. Rails not coming up when they should. However, some HP workstations do give a similar faliure if they can't boot.
    By reflowing you mean heating them up to the point solder melts and not removing them completely ?
    I have had great success with graphic cards with that procedure. I don't remove them because I will never put that back on, however, I would like to try it. Money is the big issue with buying such equipment.
    Stencils might work. Buth with more than 100 balls, there is a big chance something will go wrong. Old boards might be quite fun to learn on them
    • NxB
      • Feb 2009
      • 1595
      #42
      Removing a BGA - fairly easy.
      Putting it back.... a little harder.
      A reball kit is fine but for bigger chips I'd want something a little better than a heat gun. Something timed and with an even heat spread.
      • precision001
        • Sep 2009
        • 43
        #43
        I have read a lot about problems with reflowing large BGA chips. It is usually recommended to use a preheater, to aid in uniformly heating the chip. Since I don't have one yet, I've adapted the "toaster oven" reflow for this purpose. I consider a toaster oven too crude for any type of reliable reflow, but it's great for preheating. I have successfully reflowed larger BGAs this way but would eventually like to get one of those airbath units.
        Dealing with power issues, you must have encountered situations where you had to find suitable substitutes for mosfets. Datasheets rarely recommend a replacement, and ordering parts from China can take up to a month. Up until now, the only considerations I have taken when substituting mosfets was whether the mosfet was P-channel or N-Channel, and the pinouts of G-D-S-...
        What other factors should I be taking into consideration when selecting a substitute mosfet off of a salvage board?
        What other advice can you give on identifying and solving power-related issues?
        • Pyr0Beast
          • Feb 2009
          • 406
          #44
          I use a big electric heater for that purpose. Ceramic? heaters, the ones that glow bright orange. Since PCB absorbs IR quite well, there are no problems with it. I just place the whole thing on the table so mainboard sits on top of it. It uses around 400W and it is fairly enough to heat the PCB all the way to 200°C or more. Hot air gun does the rest
          (I also place a small drop of SMD paste on top of the chip. Once it melts completely, temperature for reflow has been reached)
          I sometimes pick the same type of mosfets that were 'blown' if I have the chance. Esp. in TV equipment, I don't like to alter circuits too much, might cause unpredictable results. However, sometimes you do have to do it.
          Otherwise, you need a replacement. My first selection is by package. Next are operating voltages, Vgs (20V) and Vds (30V) - for most laptops. Then, from what is left, I choose the one with low Rds(on) and low gate charge. If both are better than the one that was already 'installed' I go for it.
          Most circuits aren't critical, but it is sometimes preferred to reduce switching losses by replacing upper mosfet with the one that has low gate charge and the lower with low Rds(ON).
          You really have to look as you can get worse parts for more money. I usually just 'stock' some good parts and replace everything with them. They do cost more, but you get bulk discount, so that evens out.
          (Also, you can look in manufacturer's diagram, what he used)
          Mosfets aren't critical in linear-regulating circuit. Switching ones are more delicate. CPU/GPU VRM's are probably the only ones you really have to care about.
          • precision001
            • Sep 2009
            • 43
            #45
            Do you know of a good supplier of mosfets? Most places won't sell them in quantities of less than a thousand.
            • precision001
              • Sep 2009
              • 43
              #46
              I have an interesting one now, an Acer aspire. It powers on by itself but displays no video. Reflowed GPU - no effect. Pressed slightly on Max8760. Afterwards, board would beep one time each second. Strange beeping sound, almost like a blinker in a car - and I was unable to determine where it was coming from. Reflowing 8760 stopped beeping, but still no video. The 8760 is the dc-dc for the CPU, and the cpu is cold when power is applied. NB & GPU get warm, but not CPU. Could this mean that the 8760 is bad? I ordered some samples just in case. I checked the resistance from the inductors like you said previously, nothing below 20 ohms. No visible damage and no obvious shorts (checked caps).
              • Pyr0Beast
                • Feb 2009
                • 406
                #47
                I order (only) from farnell.com
                They have proven friendly and reliable.
                I had Aspire 1360 in service. Power on but nothing, no HDD or fan spin. Cpu voltage sits at 1.00V.
                If it is a harsh sound, like you hear hammer knocking on some metal, I would guess upper mosfet is defective. But that is only a guess. However, you do know that sound once you hear it.
                If it is tick-tick-tick, that is the overcurrent protection kicking in.
                Probably there is a bad contact somewhere near it. How's with the voltages ?
                • precision001
                  • Sep 2009
                  • 43
                  #48
                  I'm not sure how I should be checking voltages or what I should be looking for. Should I be checking the caps near the inductors? About the sound - it was almost like that of a relay switching on and off - in a very controlled pulse - almost like it was designed to do that.
                  • Pyr0Beast
                    • Feb 2009
                    • 406
                    #49
                    Yes, pick one good ground and poke around with the other probe.
                    There are no relays nowdays afaik
                    (perhaps only for a modem?)
                    • precision001
                      • Sep 2009
                      • 43
                      #50
                      This one looks a little harder than I thought. I can read that one good mosfet is 4704 - the other is too damaged to read, but from what I can read, it doesn't match up to the 4704, so I think it is something else. I have no idea what the 16 pin chip is, but it appears to be damaged as well. I have measured zero resistance from the inductor visible in the picture to ground, and all of the small caps mounted on the PCB on the opposite side of the CPU are shorted.
                      • Pyr0Beast
                        • Feb 2009
                        • 406
                        #51
                        Can you make out even a few letters ?
                        Otherwise, unsolder everything burned. Both mosfets, burned chip and try to 'boot'.
                        Do Mosfet traces lead to this IC ?
                        It might be a battery charger controller IC.
                        • precision001
                          • Sep 2009
                          • 43
                          #52
                          New information:
                          I was lucky enough to have another one of the same model come in, with a power jack issue. I took a close look. It looks the same, except that the 4704 isn't a 4704 but instead a 6690AS. The other 8 pin mosfet is a 4800B and the 16 leg chip is a 68CAZ (G801FG). I wonder if I can replace the two chips on the bad board with the same chips I read off of the intact board. I'm concerned that because the other Satellite P205 used a 6690AS instead of a 4704, that the other two chips may be different as well. I believe that a 4704 is a P channel and that the 6690AS is N-Channel, I'm looking for verification on that right now.
                          • Pyr0Beast
                            • Feb 2009
                            • 406
                            #53
                            It is better to verify it twice.
                            • precision001
                              • Sep 2009
                              • 43
                              #54
                              I removed the first burnt 8 pin mosfet. I can't read what type it is, but the top of it says ph7sd.
                              • precision001
                                • Sep 2009
                                • 43
                                #55
                                Based on some information that I have collected, the unidentified 16 pin chip is a PWM controller manufactured by Intersil. That might explain why all the caps on the PCB opposite the CPU are showing shorted (with no power applied, of course). I wouldn't be surprised if the CPU itself is bad, but that's no big deal. The problem now is that I need to find another PWM controller, or this will never boot up again.
                                • aubrey52
                                  • Nov 2009
                                  • 29
                                  #56
                                  can you help me out dead laptop motherboards hp dv6000/6131od 434723-001
                                  i need parts y6 on motherboard by backup battery. number on part
                                  is 32.768KE i thank it a crystal
                                  thanks
                                  aubrey52. have a good day
                                    • 31063
                                    that's just a watch crystal.
                                    32.768khz is a time standard.
                                    *any* old motherboard will have one.
                                    • aubrey52
                                      • Nov 2009
                                      • 29
                                      #58
                                      STJ thank lot
                                      i found that out and order 3 from digkey
                                      32.768ke
                                      got in to day fix mother board
                                      here is digkey part number SE2417CT=Nd
                                      95 cent a prics
                                      thanks
                                      aubrey52
                                      • precision001
                                        • Sep 2009
                                        • 43
                                        #59
                                        How did you know that part was bad? What problems was the DV6k exhibiting? Was the repair successful?
                                        • precision001
                                          • Sep 2009
                                          • 43
                                          #60
                                          I have an AMD based DV6000 motherboard in pristine condition. No power. No burnt mosfets, and no caps appear to be broken/shorted. When connected to a power jack, the LED indicator lights, indicating that there is no short, at least not in the beginning of the power circuit. Where would you recommend I begin?
                                          • Geeker007
                                            Friend messed up my laptop motherboard while working on my bench
                                            by Geeker007
                                            Hi All,
                                            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                            I have not tried putting...
                                            06-16-2025, 01:40 PM
                                          • Username338
                                            Laptop BA92-09470B motherboard schematics
                                            by Username338
                                            Thank you for deciding to read this topic!
                                            Laptop: NP700Z3A-S02RU
                                            Motherboard: BA92-09470B
                                            I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
                                            I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
                                            03-09-2025, 03:52 PM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
