Laptop Motherboard Repair
This topic is closed.
  • precision001
    • Sep 2009
    • 43
    There are enough smart people registered on this site for us to compile an effective guide for testing, isolating and repairing motherboard failures.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Laptop Motherboard Repair
    I personally don't work on laptops, I can't stand them............but on that note, a forum dedicated to those who want to work on their boards isn't a bad idea. Input?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • precision001
      • Sep 2009
      • 43
      Well, I have brought back many boards so far, but probably have about a 30% success rate. I am sure that I could increase that if I understood more about how they work. Most of the boards that I have repaired had failing (and buzzing) power mosfets or had BGA chips that lost contact with the pads. I am interested in learning what should be tested first when diagnosing a "dead" board, and where to begin. I recently learned that the Maxim chips (square little chip) controls power to various parts of a motherboard, but beyond that I know little about them or how to test them.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        i second adding a section. it would be informative, and i have tons upon tons of dead laptops and access to a place where i could buy more.
        sigpic
        (Insert witty quote here)
        • precision001
          • Sep 2009
          • 43
          I suppose a good place to begin would be learning how to test the VRM circuitry of a laptop motherboard. The VRM testing procedure here (https://www.badcaps.net/forum/showthread.php?t=600) looks very helpful for desktop motherboards, but I don't know how I would apply that to a laptop. An exhaustive search has only yielded me a few schematics, so I think it is safe to say that most repair work must be done without a schematic. But where to begin? So far, I know that the 8 pin IC MOSFETS on the motherboards drive circuitry, and when they fail, the board may not turn on. The same with the Maxim chips. But I don't know how to test an 8 pin mosfet or if this is even a good place to start. Can these components be tested, in circuit - with a multimeter? Perhaps a good place to start is to simply reflow the Maxim chips and try to power the unit on. I heard that their joints can open over time. Removing chips around for no reason has never worked for me, and often done more harm than good. I have a hot air rework station, but it's important to think before you start removing things.
          • precision001
            • Sep 2009
            • 43
            New Information: Visit Maxim-IC (https://shop.maxim-ic.com/storefront/searchsample.do) - from there you can type in a Maxim chip #, and find out what it does. This will eliminate the need to check chips that have nothing to do with the problem you are experiencing. You can even order free samples from their site once you register. Apparently, the trick to finding out if a chip is bad or not is to find out if it is shorted. I'm still trying to figure out how to do that.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              I think its a great idea! I don't see me fixing any as I had to go download a repair manual just to get the keypad out of my Dell...LOL
              Mark Twain
              John Paul Jones
              Rod Serling
              • Phaihn
                • Jan 2009
                • 842
                i cant stand laptops ither i always prefer a desktop.
                My Computer.
                AMD APU A4-3300 2.5ghz 1mb cache
                Motherboard GigaByte GA-A75M-S2V
                Kingston HyperX Blue DDR3 8GB (2x4GB)
                SB Audigy 2 ZS [B800] Sound Card
                500GB WD Caviar® Blue™
                1 Terabyte WD Caviar® Black™
                2 Terabyte WD Caviar® Black™
                • precision001
                  • Sep 2009
                  • 43
                  Can anyone provide anything productive toward this project?
                  Does anyone know of a reliable way to check if a particular chipset is dead or shorted?
                  • kikkoman
                    • Jul 2007
                    • 691
                    the most telling way i can think of right now is a port80 card. (they come in miniPCI too.)
                    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                    • precision001
                      • Sep 2009
                      • 43
                      That may be true, a diagnostic card can be helpful, but what about at the component level? Testing whether or not a capacitor is capable of charging, whether diodes are functioning properly. I have gone through motherboards and checked every capacitor, diode and resistor to no avail. If all of those components appear to be ok on a multimeter, then what?
                      I started comparing values before and after plugging a laptop in. I started noting parts of the motherboards that had power before I pressed the power button. There's a wide variance of power that goes throughout the boards, even when they're "off" - from 3 volts all the way up to 19. But to trace a dead board seems difficult on a laptop. I'm particularly interested in learning more about testing MOSFETS and power chips - and understanding the parameters in which they are designed to work. At the very least right now, I know that when a laptop is plugged in, I should be detecting various currents throughout the board. If I'm not, I need to investigate why - and whether it is normal or not.
                      • kikkoman
                        • Jul 2007
                        • 691
                        at component level? a pretty tedious process. in many cases there's no (deep level) service manual which doesn't make it easier.
                        this means you HAVE to rely on the datasheets for the components in question (first of all the regulator ICs).
                        then, you need a good set of tools.
                        a DMM is a must, and a scope is highly recommended. an ESR meter is nice but not mandatory if you have a scope.
                        plus all the small stuff of course. cold spray can be helpful too.
                        checking for cold joints, as you mentioned above, is a good start.
                        reflowing suspicious ones is alright as well (as long as you know what you're doing).
                        as for testing FETs, can't be reliably done in-circuit (except for plain shorts). there are good tutorials out there. if i find one in english, i'll post a link.
                        one could make this into a tutorial but there's so much that would have to be covered.
                        you should always base your approach on the symptoms and go on from there.
                        and hey, that's what this board is for. really skilled folks here.
                        i strongly second TC and ratdude that a dedicated laptop sub-forum would be a good thing.
                        • precision001
                          • Sep 2009
                          • 43
                          How would you test for "plain shorts" of an 8 pin IC mosfet? Are most P-channel mosfets the same as far as pin-outs go? I wonder if one could construct a "test jig" which could make contact with this type of mosfet - one for a p-channel and one for n - to detect if they're good or bad. I saw some ESR meters on Ebay for under $100 - but I already have a scope - its only 100 mhz though. How would I use the scope to test a cap beyond the capabilities of a DMM?
                          • kikkoman
                            • Jul 2007
                            • 691
                            you can usually tell which one's the gate (one pin) but that doesn't help too much because
                            a) you don't know if it has a freewheeling diode integrated and
                            b) as said before, you can't do the full check in-circuit. (i may be wrong so if anyone begs to differ, go ahead.)
                            finding a datasheet isn't too difficult for most FETs though.
                            as for the scope/esr thing, here's a starter:
                            http://octopus.freeyellow.com/esr.html
                            the last link on the bottom of the page ('Bare bones ESR tester') has a good circuit. it's designed for 2.3khz but if you do a clean job, the 555 is good for 100kHz (standard for ESR ratings).
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              ask, and yee shall receive.
                              https://www.badcaps.net/forum/forumdisplay.php?f=23
                              Team : 49813
                              Join in!!
                              Team Stats
                              • NxB
                                • Feb 2009
                                • 1595
                                The best I've been able to do in circuit with mosfets and transistors is seeing if they output voltage when the circuit is powered. With some stuff it seems like the whole section is shorted even if you take off the transistors. When you pull them out they test fine.
                                • precision001
                                  • Sep 2009
                                  • 43
                                  I have an HP DV9000 motherboard with that problem now. After plugging it in, it shorts out. There appears to be low resistance between positive and negative. I guess if I could trace the voltage rails I could find where it leads to and remove the mosfets in that area. I suppose after the jack, power must go to DC-DC converters to distribute power throughout the board - that must be where my short is. It's going to be a killer trying to find this, but I had an idea. What if I sacrificed an adapter, and spliced a light bulb in series? I could use the luminosity to try and find the short. Who knows it just might work!
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    see the 1st 2 posts : https://www.badcaps.net/forum/showthread.php?t=7932
                                    they talked about you model.
                                    sigpic
                                    • precision001
                                      • Sep 2009
                                      • 43
                                      That's a different problem altogether. In that situation, the system will power up but will fail to show video. In the one I've been working with - the power is shorted somewhere. Another phenomenon I'm trying to figure out is a "dead" motherboard that will spin up the cpu fans automatically upon plugging it in. I've seen this alot - where once you add power to a test PSU, the CPU fans spin up on the dead board, but nothing else happens. I'm going to be looking for thermal changes to see if I can find a failing chip, but there has to be a better way than that.
                                      • NxB
                                        • Feb 2009
                                        • 1595
                                        Its what we do for TVs. I don't know how well it will work since its only a ~19v source. Maybe with a smaller bulb.
                                        Laptop or desktop? On desktop boards its usually a dead chipset, like on the emachines.
                                        • Geeker007
                                          Friend messed up my laptop motherboard while working on my bench
                                          by Geeker007
                                          Hi All,
                                          So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                                          So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                                          I have not tried putting...
                                          06-16-2025, 01:40 PM
                                        • Username338
                                          Laptop BA92-09470B motherboard schematics
                                          by Username338
                                          Thank you for deciding to read this topic!
                                          Laptop: NP700Z3A-S02RU
                                          Motherboard: BA92-09470B
                                          I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
                                          I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
                                          03-09-2025, 03:52 PM
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
