Da0zrwmb6g0 rev g 14 volts reading
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    I have a 14v reading from the charger to the PR213 , Ive tested the charger it has 19v reading What may be the problem?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Da0zrwmb6g0 rev g 14 volts reading
    PQ22 gate voltage?? Remove PR213 and see you get 19V on pq22 side. Measure resistance on both pads of PR213 after removing the resistor.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Im having 10 mega ohms
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Yes im having 19v
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Resistance on both pads of pr213 after removing it?? You just mentioned 10 mega ohms. Which side??
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            From Vin Side
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              From Vin Side
              What about the other end??
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                6 megaohms
                • nurhan
                  • Jan 2015
                  • 24
                  • Turkey
                  Thanks for shared boardview file. I solved my problem...
                  • Sergio Kub
                    • Jul 2018
                    • 161
                    • Brasil
                    Thanks a lot !!!
                    • MisterAIL
                      PS5 digital / No Power / No Beep / Good power supply
                      by MisterAIL
                      Brought a non functionnal PS5. Apparently only a bad PSU...
                      No beep, nothing.
                      After some tests i found this :
                      - PSU is fine (12 volts stable)
                      - 12 volts line is shorted
                      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                      - By the way, nothing change. No signal, no power, no beep.
                      Mesuring all rails with my workbench psu (12 volts input)
                      - 0.00 amp drawing
                      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                      03-12-2024, 03:24 PM
                    • BTubbs200
                      Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                      by BTubbs200
                      Dell Latitude 5420 P137G
                      Board: LA-K491P REV A01
                      I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                      Board seems to have no shorts, all power rails are fine and show high resistance.
                      When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                      01-24-2025, 08:15 PM
                      MPJA 10 AMP @ 0 to 30 Volts Switching Power Supply Cap Fault
                      by sam_sam_sam
                      I have this 10 amp 0 to 30 volt switching power supply that decided to have a 630 milliamperes draw on it at 0 volts
                      I open it up to find non brands name capacitors in it
                      I am not sure how this switching power supply is set up
                      Could someone please explain how this power supply works
                      Here is the capacitor ESR results
                      (1) 47uf@50 volts 0.46
                      (2) 47uf@50 volts 0.45
                      New 47uf@50 volts 0.35
                      (1) 100uf@25 volts 0.34
                      (2) 100uf@25 volts 0.35
                      New 120uf@50 volts 0.08
                      (1) 220@25 volts 0.13...
                      10-21-2018, 10:02 AM
                    • stylishconsultant
                      un60j620dafxza - Samsung No Display Problem
                      by stylishconsultant
                      Hi All,
                      Need help.
                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                      09-04-2024, 03:26 AM
                    • novice1
                      Acer Aspire E5-574G - Not Powering On
                      by novice1
                      Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
                      This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
                      To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
                      11-03-2023, 05:53 PM
