dell 14216-1 7 beep problem any solution
  • moin
    • Nov 2019
    • India
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: dell 14216-1 7 beep problem any solution
    Measure voltage on all coils and post here. have you flashed known good bios?? On some models gfxcore will not rise without led connected in.
    • pkslowk
      Debug Card Error Code and Solution
      by pkslowk
      Sr. Motherboard Debug Error Code Solution
      1 Intel 845 E9 Bios Related Problem
      2 Intel 845 D4 CPU Socket Related problem
      3 Intel 845 37 Bios Related Problem
      4 Intel 845 7C Bios Related Problem
      5 Intel 945GCPE 34 Bios Related Problem
      6 Gigabyte 845 2 Ram Related Problem
      7 IBM Server A6 A7 Ram Mismatch Problem
      8 Asus 845 29 CPU Related Problem
      9 Lenovo I946 97 C-Mos Jumper related
      10 Gigabyte 845 A0 CPU Related Problem
      11 Asrock G31M-VS D7 Bios Related Problem
      12 Compaq 845 BD-70G B0 CPU Socket Related problem...
      01-28-2021, 12:51 PM
    • toti24
      (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
      by toti24
      dell precision m4600 laptop
      i7 2760qm
      8gb ram 750gb HDD
      intel hd 3000 integraded and nvidia quadro 2000m
      pleasea bear with me english isnt my language and ill try to be as clear as possible
      note i live in mexico in a very small town..
      thank you.
      laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
      the brick happened when i was installing win 10 using usb.
      used rufus and officia microsoft.iso
      it finished copying files from usb...
      03-06-2022, 08:39 PM
    • SDNarcia
      Dell 15R-5521 keyboard problem (KBC?)
      by SDNarcia
      Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
      As additional information,...
      07-20-2024, 10:47 PM
    • Achille15
      Dell N5110 problem
      by Achille15
      so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
      03-29-2025, 04:41 PM
    • ktmmotocross
      Dell 15 3520 LA-L24LP win only 2.5V - PS_ID problem?
      by ktmmotocross
      Hello.
      Have this Dell 15 3520 LA-L24LP that have not power swithed to VIN - only 2.5V . I measure that it have 8.9V on PS_ID whis is little high for me. but im not much familliar to this dell charging. i cannot find exact schematic but it look like that LA-L241P is simmilar. "ACDRV" is 4.5V here
      i try to find guide for charging on this site, but cannot find it. have somebody link for it?
      any help how to aproach this?
      09-12-2025, 02:45 AM
