dell 3521 screen light on but no data
  • mo000
    • Nov 2017
    • 285
    • algeria
    the laptop turn on with only screen backlight but without data .
    and makes beeps ; one big beep and 7 others
    but sometimes after i clear cmos by take cmos battery out the laptop work normally
    i try to change the cmos battery and flash bios and ec and the same problem .
  • KvnTM
    • May 2018
    • 434
    Re: dell 3521 screen light on but no data
    Most Common Fixes:
    1 Beep: Replace the motherboard / system board.
    2 Beeps: Reseat the memory or replace the memory.
    3 Beeps: Replace the motherboard / system board.
    4 Beeps: Reseat the memory or replace the memory.
    5 Beeps: Replace the CMOS battery.
    6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
    7 Beeps: Reseat or replace the CPU.
    8 Beeps: Reseat the LCD cable or replace the LCD screen.
    Found on:
    Dell Inspiron 15 (3521) Beep Codes Diagnostic Indicators
    According a video it has something to do with UZ1.
    I'll try to get a schematic and get back to you.
    EDIT:
    I attached 2 schematics. One for r1.0 and one r.04. Check your board markings for the correct one.
    Take a look at UZ1 and measure for +1.5V and +1.5VS. This seems to be a known failure point. Replace UZ1 if +1.5VS is missing.
    One little sidetone:
    Don't flash EC/Bios out of the blue if you don't know what's going on. Always look at power rails first.
    • mo000
      • Nov 2017
      • 285
      • algeria
      Originally posted by KvnTM
      Most Common Fixes:
      Found on:
      EDIT:
      8 beeps lcd failure
      but i change the screen and same problem
      if 1.5vs missing the laptop turn on with black screen no backlight .
      the 1.5s is found and in this time the laptop seems works fine but the problem maybe appears in anytime .
      • KvnTM
        • May 2018
        • 434
        Don't count the long beep. So you got 7 beeps.
        Does magically work again?
        I don't really understand what you are trying to say..
        • mo000
          • Nov 2017
          • 285
          • algeria
          yes the laptop works fine but honestly i don't know how .
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            7 beeps problem wont go away automatically. If it is 8 beeps problem and you are getting display on a couple of occassions , then very likely your lvds cable is somewhat broken.
            • mo000
              • Nov 2017
              • 285
              • algeria
              yes i think so .
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • hcinne
                Dell G15 ryzen edition black screen 2 amber 1 white
                by hcinne
                I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                07-23-2024, 07:56 AM
              • jasonbay13
                Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
                by jasonbay13
                it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
                PU200
                pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
                pin 8 vreg3 = 0v
                pin 13 en = .2v
                pin 1,6 entrip1,2 = 0v
                b+ and b++ = 19.5v
                +5valw = 0v & 25+ohm to ground
                +3valwp = 0v & 25+ohm to ground
                i cleaned the board up just a little and can get more pics.​
                where should i be looking? thx...
                09-25-2025, 10:54 PM
              • HTR-Informatique
                Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                by HTR-Informatique
                YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                I also changed the screen because the PC fell and the screen was broken.
                I changed the battery with a new and original battery.
                I also had corrosion/oxidation on the...
                02-09-2025, 06:51 AM
              • siuras676
                Dell XPS Plus 9320 blue screen and rebooting
                by siuras676
                I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
                First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
                However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
                Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
                04-07-2025, 12:10 PM
