I am still very much a newbie , so please forgive my lack of knowledge, I am working on acquiring it, by doing, my best way of learning. I have a 820-3115 board which went from doing great to a sudden death, albeit with light on mag charger still on. I checked the power rails up to PP5V_S3, which is not present. One of my laptop repair gurus suggested to pour alcohol on the audio section and induce voltage into PP5V_S3 to trace the short in that line. I was wondering if I could not just measure the resistance or lack of resistance over the various caps and resistors in that line. If a cap or other component is shortened, would it not beep in diode mode over that component? I have a power supply, but I have never done any inducing power yet, and I am nervous that I might destroy something...
2012 13"Mbp 820-3115 sudden death
Tags: None
Re: 2012 13"Mbp 820-3115 sudden death
You have to confirm there is actually a short to ground before injecting voltage. Measuring resistance mode to ground on that rail first.
It can be 100 other things causing your problem.
First is to remove the board from the machine and inspect for liquid damage (those rarely die suddenly for no reason). Then disconnect everything except fan and DC-in board, and plug Magsafe in. It should turn on automatically with fan spinning.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
Thank you for your reply Piernov. I did as you suggested and took out the board. I would like to add that this board came from an Ebay reseller of logic boards, and it did well for the first boot up, in which I tested the GPU by running "Heaven", which it passed. The next time I tried to boot it was dead. The condition of the board is actually quite fine, no corrosion. It looks like there had been some work done by the seller, around U1800 and U2600, judging from the flux residue. I checked the resistance to ground in diode mode on some components on the missing PP5V_S3, such as C6608 and C6607, and they read 1559.However, on the 200 ohm setting on my meter it fluctuates wildly, and then drops to OL. ( I must be missing a bit of info here on what the difference is between diode mode and regular ohm measuring) Can you fill me in on what this might mean? And I have no fan spin....yet. Maybe later with some help...Also, should I have a RAM chip in place to allow for fan spin?Last edited by jurgenkoppen; 11-05-2019, 11:55 AM.Comment
Just as an explanation for your measurement:
When you measure a power rail you inject a little voltage from your multimeter into it which charges the cap's on that rail. Capacitors have a very low resistance when discharged which rises while charging. This is why you see fluctuations on your multimeter. OL just means overload which indicates that the value is out of range. >200 ohm in your case. This is a completely normal and expected behavior.Comment
Thank you KvnTM for shedding some light on this aspect for for me, all the way from Bayern. So in doide mode then the diode prevents the discharging and I get a more stable value of 1559? Did I get this one right?Comment
Bayern is great. Don't think about lederhosen, Bier and Brezeln though. This is not how we look like haha.
Anyways..
In diode mode you measure the voltage drop across your probes. Pretty straight forward.
Measuring a power rail in diode mode doesn't really make sense in my opinion.
One use case for diode mode:
Imagine you have an unknown Diode and you want to know how much voltage it drops. On a normal diode your multimeter would read something around 600-700mV.
The same can be done if you want to know the forward voltage of an unknown LED.
Those are just examples and i don't really know any practical reason to test a power rail in diode mode besides the "beep" when something is shorted. It's just easier to find shorts I guess... Maybe someone else can elaborate further..Comment
Ja ich war schon mal da in Bayern, ich bin selber vom Kohlenpott...Duisburg.Und wir haben auch nicht alle Kohlestaub im Gesicht.
To the point:
Oh Boy, I really have to back up and read up on diode mode versus resistance measurements before messing about any more with trying to understand logic boards. Louis Rossmann had recommended using diode mode for quick measurements. So my reading in diode mode is the voltage difference in mV , and not related to ohms at all! To many gaps still in my overall understanding of electronic circuits. Back to the basics electronics study...
Thank for helping me see where to start...Comment
Ich komme ursprünglich aus Hamm. Ist nicht weit von DuisburgJa ich war schon mal da in Bayern, ich bin selber vom Kohlenpott...Duisburg.Und wir haben auch nicht alle Kohlestaub im Gesicht.
To the point:
Yes, diode mode is indeed a quick way to find shorts because the meter beeps on a short so you don't have to move your eyes from board to the meter all the time. As you mentioned it has nothing to do with resistance. Thats what the forum is for.. Sharing knowledge and helping others in need. Im pretty sure someone is able to help you further. Im not into MacBook logic boards that much I only have basic knowledge about their power rails. In fact im writing this on a mid 2012 MacBook with the same logic board. Those mid 2012 MacBooks are one of the most reliable ones with only one major known failure point which is the sata cable. I can tell it is really reliable. I carry it every day and abuse it a lot with high cpu loads/temps. Never let me down once.Comment
by samstownHello, I got an Acer N19C2 that doesn't show sign of life. It was working properly and died while I was typing. No charging LED.. nothing, so I opened it and I found schematics on this forum,
https://www.badcaps.net/forum/showth...ighlight=EH7LW
which is awesome.
Using my multimeter, I can see 19V on PQB3 but not on PQB4. Does that mean for sure that this Mosfet PQB3 is the problem ?
Thanks... -
by smic717394Hi,
I bought a mac air 2012 very cheap, because the customer didn't want to fix. After reflowing the ram chips the laptop works fine, I tested the ram and no error. But The fan goes at max speed after few seconds. Running the Apple diagnostic finds an error 4SNS/1/C0000008: Th1H--124. and the cpu usage is like 300%, After disconnecting the webcam cable that on the 2012 model is on the IO board, the laptop, the laptop runs fine, and running the apple diagnostic finds no errors. So the problem is related with the webcam, but I suspect the problem is no the webcam but the light sensor.... -
Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
I'm new to soldering but the only feasible way to fix this issue is to do something myself.
MY QUESTION:
I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)... -
by bastienOBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
This is the new database for FlexBV
it's optimized to work with it
by using board ID has Default name, give us the opportunity,
to use other diode board data with sibling board or family board
I Merged the whole data (optimal)
A2991 A2992 M3 -> -> 2 Entries diode data M1
A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
A2442 A2485 A2779...-
Channel: Schematic Requests ONLY!
by barry101Hi everyone.
I hope someone has some suggestions on how to proceed with this issue.
I have an Apple A1286 2012 MacBook Pro with 820-3330 Logic board. My customer purchased this from me in full working condition. Unfortunately, it overheated on him due to being left running on his bed.
Investigation showed the LCD Backlight was not working (had a latent image and external monitor worked), the battery was no longer functioning (system couldn't read it or charge it) and the Samsung 850 EVO SSD was dead (not seen by finder or disk utility). Quite the trifecta.... - Loading...
