need advice for soldering station durable
+ More Options
Posts
  • String2016
    • Nov 2015
    • 2229
    • philippines
    anyone can share what is your good and durable soldering station?i buy cheap one it cannot last for a month, also already tried hakko 936 still the same cannot last for a long time.
  • KvnTM
    • May 2018
    • 434
    Re: need advice for soldering station durable
    You are doing something wrong if a hakko 936 fails within a month.
    Maybe your iron is set too hot?
    Always keep a solder blob on the tip when not in use.
    Use proper cleaning methods for the tip.
    If your tip is oxidized: Let it heat up, put flux on it and let it burn. Clean your iron with a wet sponge or even better with "steel wool". Apply some solder and turn it off. Never let the iron cool down without solder on the tip. This will ruin them really fast due to oxidization.
    • String2016
      • Nov 2015
      • 2229
      • philippines
      thanks for the info i will try your advise
      • KvnTM
        • May 2018
        • 434
        Will help for sure. I ruined many tips in the past because of oxidization.
        I haven't ruined one since taking a little bit more care for them.
