Best Method to Align Small IC while replacing
+ More Options
Posts
  • IamPritesh
    • Aug 2017
    • 354
    • India
    It usually takes a lot of time to place a new chip perfectly. For example (charging ic or 3/5V IC ). I understand lots of practice is required but I was wondering what is the best method you use .Which hand do you use to hold the heat air blower and so on.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Best Method to Align Small IC while replacing
    It depends on practice as you have already said. Its important to use good quality flux so that the ic gets it to place when heated even though not aligned very perfectly.
    • IamPritesh
      • Aug 2017
      • 354
      • India
      Which flux do you use ? Do you grip the IC with the help of a Tweezer while you apply heat ?
      • anshad
        • Nov 2010
        • 249
        Which hands to use depends on what you feel comfortable. Try yourself using both hands and which one you feel unshaken and steady while doing the job, stick to that one. Refer the below video, its the way most of the professionals solder QFN chips
        https://www.youtube.com/watch?v=c_Qt5CtUlqY
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I use AMTECH flux. No i dont grip the ic while applying heat.
          • IamPritesh
            • Aug 2017
            • 354
            • India
            This one ?
            https://www.amazon.in/Generic-O2IBG-.../dp/B01FA6G4B2
            What is Solder Paste ? I see in many videos,people are applying some grey paste like substance on the board before placing the IC.
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              soldering back a small qfn need to study the situation. if i remove for example a 3.3 5v ic, i use flux to remove it, and without clean old solder i go for the new one. when heating the board i then press a bit the ic on pcb. when all joint get connected ull see that the chip stay in place alone. if needed i keep a small pressure over it with tweezer till it get cold enought and soldered perfect. after that i use a small iron tips to pass all the corner and joint with flux and solder.
              if u remove an ic, then clean the board with flux and solder wick u can apply a small amount of solder on pins and center pin. then when soldering new chip use good flux, apply a good pressure on the chip till it get all extra solder out of it. keep pressing with tweezer till it cold down. with a solder tips remove extra solder from corner and get a pass on all side of ic. ur done.
              as for centering the ic, if u have a magnifier lamp with led illumination ull be just fine centering it perfectly.
              practice a bit and ull be the master of qfn soldering
              for flux i use kingbo but also amtech 559 (green bottle) is ok, but it need to be original, not fake.
              • dj_ricoh
                • 2073
                • uk
                This one ?
                do you know what is paste? well, solder paste!
                PASTE -a thick, soft, moist substance typically produced by mixing dry ingredients with a liquid.
                • IamPritesh
                  • Aug 2017
                  • 354
                  • India
                  Why does anyone use this if we already have a good flux. Is solder flux enough?
                  • IamPritesh
                    • Aug 2017
                    • 354
                    • India
                    Thank you sir. That is very insightful.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Getting a original flux is pain-most are chinese crap where some portion of the original flux is mixed with grease and sold as original. @pritesh, you are based in India and can buy it from Nehru Place,New Delhi instead of buying online. If you need contact info PM me, I'll give you contact number of vendors in New Delhi where you can get original Flux.
                      • KvnTM
                        • May 2018
                        • 434
                        I usually draw the outline of the chip onto the board before removing it when there is no silkscreen. Surface tension of the solder will do the rest. Good flux is also very important.
                        • IamPritesh
                          • Aug 2017
                          • 354
                          • India
                          Interesting. What do you use to draw the line that doesn't wipeaway when you clean the area before seating the new chip?
                          • KvnTM
                            • May 2018
                            • 434
                            It really depends on the chip. Usually a normal pencil does the job and careful cleaning with a q-tip.
                            UV solder mask also works for this kind of stuff. It is available in many colors. It won't wipe away and is somewhat permanent. Just put tiny drops on the corners of the chip and cure it.
                            • jasko_jacker
                              • Oct 2014
                              • 1137
                              • italy
                              I have tried many flux, I use three types:
                              Insat Hight Activity Rosin to remove bad bga
                              Insat VOC-Free water to inject under BGA for reflow
                              But the best for small component or reballing is
                              ERSA Fluxpaste F-SW 32, leaves no residue after the
                              welding, excellent activation point, even if only with
                              infrared
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                                HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                                This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-12-2024, 03:44 PM
                                HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                                This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 03:36 PM
                                HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-4570 Specification for Upgrade or Repair
                                This specification for the HP ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G1 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                09-12-2024, 03:28 PM
