Random Shutdown - HP laptop
  • IamPritesh
    • Aug 2017
    • 356
    • India
    The Laptop shutdown randomly. Sometimes in few seconds as soon as you start and at then there are occasion when it works fine for an hour and then shuts down.So there is no fixed time ..it can few seconds, few mintutes of few hours. Most the of the time it shutsdown within a minute ..even in BIOS menu.
    Model Name : HP Pavilion Notebook - 15-ab029tx
    What does these symptoms point to ??
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: Random Shutdown - HP laptop
    Remove battery and try again.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      Tried it . Doesn't changed anything. Even replaced the cmos battery
      • KvnTM
        • May 2018
        • 434
        Sounds like a heat issue to me.
        Or maybe a bad solder connection somewhere. Try to flex the laptop in all directions a little bit while on.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          very difficult to say what is the fault in such scenario as symptoms are not constant. as@kvntm has said may be bad solder joint, corrosion somewhere on the board. Can be 'coz of bios also, so do flash a tested bios. In some cases it is caused by a bad sio chip as well.
          • IamPritesh
            • Aug 2017
            • 356
            • India
            Thanks for your valuable inputs
            Can BIOS cause such issue? I thought it is only responsible for the startup ..
            • RethoricalCheese
              • Mar 2013
              • 1518
              • Estonia
              Last time I had this problem with HP, I reprogrammed BIOS, which did not help and then removed battery, which did help. Maybe it was somehow the combination of these two actions.
              • IamPritesh
                • Aug 2017
                • 356
                • India
                In your case did it work for few hours occasionally ?
                • RethoricalCheese
                  • Mar 2013
                  • 1518
                  • Estonia
                  Did not test much, usually in a few minutes.
                  • KvnTM
                    • May 2018
                    • 434
                    If it was a bios issue it won't shut down randomly or after hours. Someone on this forum pointed out that intel cpus will shut off if the me region is incorrect/corrupted but that will happen after 30 minutes.
                    Just give the laptop a few flexes or shake it a little. This problem is very hard to pinpoint. I'll bet for a bad solder connection that fails due to heat expansion.
                    • Nurshad
                      • Oct 2019
                      • 75
                      • bangladesh
                      hp probook 450 g0 thermal shutdown occurred problem solution help
                      Change fan but not solved
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Mb marking?? It has to do with thermal protection of SIO.
                        • mon2
                          • 14201
                          Review the voltage readings to ground from the thermal sensor.
                          What is the voltage to ground for PM_THRM# pin ? If this voltage is LOW, then this sensor is alerting the logic board that the temp is too high so shut it down.
                          Meter in DC volts mode -> red probe to PM_THRM#. Black probe to ground.
                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                            09-06-2024, 09:30 PM
                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-06-2024, 08:47 AM
                          • RdeveLabs
                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                            by RdeveLabs
                            To all the members here...
                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                            05-05-2025, 04:59 AM
                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-07-2024, 06:11 AM
                            Microsoft Surface Laptop Surface Laptop Go 2 Notebook Go 2 Specification for Upgrade or Repair
                            This specification for the Microsoft Surface Laptop Surface Laptop Go 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop Go 2 boardview and Surface Laptop Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
